Dead PMP Sunplus Recover Guide (UPDATE)
  #31 (permalink)
Old 5th Aug 2008, 5:33 am
Default Re: Dead PMP Sunplus Recover Guide (UPDATE)
hi,
i have sunplus 3052a chip iy can be detected by windows with drives G and H, the problem is i cannot open drive G the other drive H ok i can see data folders, please advice how to correct this problem?
i tried with fmpro but alwats ats no device detected
tia,
  #32 (permalink)
Old 5th Aug 2008, 11:46 am
"Ali44
First thing is that you dont have to worry about the H-drive becasue the H-drive is assigned for the memory card .......... if you insert the memory card in it then that drive will open too.AS well as the other issue like when you press the power ON button only the power led got power.This can be the problem of the software or the hardware.In hardware this can be solved by changing the OSCILLATOR which is normally like the small metal tube and have two legs and if you see it closely there normally two values ..........one can be 27.000 or 24.000.........so by changing that too can solve your problem..........the other thing in hardware which can solve your problem is the SMD-Transistor which is of 5 legs and have Number like (A36z or A17u or HX-VG or HX-UG or A17a).In software and for the ISP programme like FRM PRO for software ,first you have to put that MP4 player into camera mode.
I think that is enough helpfull for you otherwise give me more details of your MP4 not the outer details ........... "
first greetings to u all.
i 've also similar probs like u guys - only that i found out at this 27Mhz oscillator 4 problematic or low quality - when i heat it with soldering iron the pmp comes to life then when it cools down everything hangs/crashes. some moisture absorption or bad Taiwan electronics. can some body give me the pinout/datasheet of the oscillator vis a vis pads on the motherboard ? how to format the data area of the flash? no support 4rom one of the best multi-billion coy to not issue a datasheet or application note. only push s(h)ell $$$ by selling craps like this. read their quality policy on h-t-t-p-://w3.sunplus.com/about/0104.asp--.and now when this pmp kaputs they will not replace it - Cambridge, Forbes, Innovation. Anybody out their modding this toy for something better.i know it was a bad investment rather expenditure. can somehow make a spy camera with recording facilities, then re-tailoring of the firmware comes.
  #33 (permalink)
Old 5th Aug 2008, 11:54 am
has anybody explored another connection behind the sunplus chip? USB, JTAG what?
  #34 (permalink)
Old 5th Aug 2008, 1:33 pm
eeeks
what you exactly want to know and you have copied all what i wrote.I think the better is to just tell your problem to ask for the solution......
  #35 (permalink)
Old 12th Aug 2008, 7:21 am
i have problem to convert video for my spmp sunplus
the video freez sometimes and after dyscronisation betwen audio an video
can someone help me.thinks
  #36 (permalink)
Old 22nd Aug 2008, 1:45 pm
The link don't works :-(
http://pmp-sunplus-recover.4shared.com/
  #37 (permalink)
Old 23rd Aug 2008, 5:21 am
my pc with windows xp cannot detect my sunplus 3052a spmp as device in order to upgrade or extract the firmware, i tryed different combination of key: ok+a, b+ok,esc...etc but no thing i have only drive i and h to upload mp3 and video .
  #38 (permalink)
Old 24th Aug 2008, 6:21 am
but all The links don't works in this subject
  #39 (permalink)
Old 24th Aug 2008, 10:51 pm
hi,
another sunplus 3052 chip(not sliding type) hang on "light your life" on display, when connect to pc it can be detected as image device but not install driver automatically. please post site or link where to find driver.
tia,
  #40 (permalink)
Old 29th Aug 2008, 4:18 pm
instead of using dos VDK,
you might try VDKwin, much easier!!
http://petruska.stardock.net/Softwar...re.html#VDKWin
Sunplus SPCA536 dead player repair guide paulareno Dead Players 1 23rd Feb 2009 7:51 am
[Solved] Dead player, recover guide no help... KeReMiD4O2 Support and How To 2 26th Nov 2008 4:39 pm
Sunplus SPMP3050-3052A Update lizchka Support and How To 1 2nd Oct 2008 7:45 am
buying a new one to recover the dead one? tom99 Dead Players 6 23rd Aug 2007 3:14 am
dead mp3 player guide tarunvishal Dead Players 0 17th Jul 2007 12:38 am
