Dead PMP Sunplus Recover Guide (UPDATE)
  #41 (permalink)
Old 26th Sep 2008, 4:10 pm
Default Re: Dead PMP Sunplus Recover Guide (UPDATE)
what work ?
all web site close and firmware not found
what work ?
  #42 (permalink)
Old 5th Nov 2008, 12:41 am
I have an IC-P4708.
With a SPMP3052A.
Firmware ver is; 4.01.080714.
I tried all kinds of key combinations but cannot get into webcam mode.. wonder if they disable this.
It does have an item in the tools menu to upgrade from SD or flash, but I wonder if it does make a copy of the existing firmware first?
Anyone knows what the key combination is and if its safe to upgrade from flash and does it make a copy (store) of the original firmware?
  #43 (permalink)
Old 11th Nov 2008, 12:16 pm
@ eeeks: I may be a bit late but if you still need the info, the oscillator has no "pinout", it's actually not an oscillator but simply a quartz crystal with 2 pins, the oscillator is inside the chipset itself.
So just buy a crystal of the same frequency and solder it in, doesn't matter which way around.
  #44 (permalink)
Old 1st Dec 2008, 11:48 am
Hi, im from Uruguay, sorry for my english..i have this one:
http://img111.imageshack.us/my.php?i...2081730qa6.jpg
and i saw in this page: http://articulo.mercadolibre.com.uy/...o-fm-audio-_JM
that my pmp can support radio fm, but don't have it!! it has the version v321.56787.
and some people says that it can be used like a web camera...i cant do that
someone can help me?
thanks!
  #45 (permalink)
Old 3rd Dec 2008, 5:27 am
hello,
I have Sunplus chipset SPMP3052A and it has a camera plus the SD memory slot, it looks like this one
it's dead and when I connect it to the computer the greed led lights but nothing happens on my computer and no devices are detected, and when I plug the charger the red led turns on and it wont turn on, I tried A+OK and B+OK and OK+Down and tried M before connecting the USB cable and nothing worked, any advice?
  #46 (permalink)
Old 7th Dec 2008, 8:05 am
Hi, I'm trying to follow this guide, but i fail in step zero.
In other topics said that for my device (http://freedata.com.cn/products_info.asp?code=4&id=105) you have to press a hidden button (thru line in).
When I plugged the device, Windows sent a message that said that a new USB device was connected. I search the drivers in the CD that comes with my device but Windows says that can't find right drivers.
Someone have the drivers?
Another thing, link for tool needed for the tutorial is broken.
Thanks.
(Sorry about my English)
  #47 (permalink)
Old 7th Dec 2008, 10:48 am
search the forum you will find that drivers in 2 or 3 places
  #48 (permalink)
Old 7th Dec 2008, 10:51 am
Now my divece stops working and i don't have firmware neither drivers... please help!
  #49 (permalink)
Old 16th Jan 2009, 2:51 pm
I try to use all firmware from this site in my pmp and nothing working corectly Sad Image is mirrored or key not responding.
PCB is PL25-3052-RK301A+-V20 chip 3052a, I found site with propably god firmware but i can't download it , can anyone help me ?
site adress http://www.zhxqxfy.com/html/41/t-16141.html
sorry for my poor english
  #50 (permalink)
Old 16th Jan 2009, 10:19 pm
HELP ME PLEASE!!!!! I have a similar MP4 player (well not a player right now....) but it doesn't have the slide screen the GUI is IDENTICAL I also completely screwed myself by trying to update the firmware FRM Pro got to "Update RSV" and sat there eventually I got stupid and pulled the USB cable out.... (yeah I know smart) I tried and tried to find a firmware the I did.... I got it programmed (sort of ... same thing happened) now it will turn on but when it says "Light Your Life" or whatever it is mirrored not just backwards but the letters are facing the wrong way wth?!?!?!? so.... I've learned now that I need not only a working firmware but ALSO the Reserve(?) AIMG and BIMG and of course anything else I screwed up ...... this sucks..... this thing isn't even mine (I tried the upgrade because I had success couple years ago and this one kept not wanting to play NES games and sometimes it froze) I have to give this thing back in like 2 weeks HELP HELP HELP PLEASE
Sunplus SPCA536 dead player repair guide paulareno Dead Players 1 23rd Feb 2009 7:51 am
[Solved] Dead player, recover guide no help... KeReMiD4O2 Support and How To 2 26th Nov 2008 4:39 pm
Sunplus SPMP3050-3052A Update lizchka Support and How To 1 2nd Oct 2008 7:45 am
buying a new one to recover the dead one? tom99 Dead Players 6 23rd Aug 2007 3:14 am
dead mp3 player guide tarunvishal Dead Players 0 17th Jul 2007 12:38 am
