dead mp4 player stuck on blue hour glass screen
Old 12th Mar 2008, 12:45 am
Default Re: dead mp4 player stuck on blue hour glass screen
It was probably hacked to show 8 Gb, so yes, you have to format it in windows. You can find the real capacity of your player's memory by opening it, on the big chip (samsung or hynix) you'll find a code. Compare it with these ones here http://s1mp3.org/en/docs_hwspecs.php#flash . Read this too http://www.mympxplayer.org/1-vt2400....r=asc&&start=0 Good luck
Old 13th Mar 2008, 1:39 am
i managed to format it and it is really hacked i think cause now it shows 3.8GB instead of 8GB. but the player's screen is still blank. the player now works fine as a usb memory but the player won't switch on. is it because i used a wrong firmware?
Old 13th Mar 2008, 2:51 am
Hi there jimmys,yes probably you have flashed a "not so" compatible firmware to your player,the firmwares doesn't matches the LCD of your player.
Old 13th Mar 2008, 10:21 am
can anyone tell me what's the right firmware to use? i tried the above two but no good and i really searched hard but didn't find one that matches my player's characteristics..
Old 13th Mar 2008, 10:58 pm
jimmys, your player would be using the v9.0.xx series firmwares here: http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of telling which firmware would work with your player, you'll need to try all of them.
Good luck.
  #16 (permalink)
Old 16th Mar 2008, 6:52 pm
firmware not compatible with LCD. can't help further. sorry. u have to search more firmware to try, good luck.
blue screen with a sand glass in the middle of the screen jacko-2009 Dead Players 3 26th Jan 2009 12:36 am
froze up to an hour glass screen chrystal0925 Dead Players 7 4th Nov 2008 9:38 am
Stuck on hour glass kamalrohit Support and How To 1 14th Jan 2008 2:26 am
3rd gen mp4 stuck on hour glass???? patches22 Support and How To 1 23rd Aug 2007 4:56 am
MP 4 Player stuck on hour glass mikc67 Support and How To 9 1st Jul 2007 7:00 am
