dead mp4 player stuck on blue hour glass screen
Old 3rd Mar 2008, 1:02 pm
Default dead mp4 player stuck on blue hour glass screen
hello.
i have a dead mp4 player (stacked in blue hourglass screen). i 'd like to fix it by installing a new firmware but when using the MP3 player upgrade tool it does not recognize my player although i have installed the adfu driver.. what should i do?
thanks
Old 3rd Mar 2008, 8:06 pm
Hi there jimmys,what you mean its not recognized?You mean the error message "Device Not Detected" appears when you run the upgrade tool?Do you have already the suitable firmware for your player?
Old 4th Mar 2008, 4:49 am
no error message appers.. the Begin Upgrading button cannot be pressed.. i believe i have found the firmware. do i have to select the right firmware for the button Begin Upgrading to be available to press? and about the adfu driver is it generic?
Old 5th Mar 2008, 8:57 pm
the firmware you have found is not compatible for your player.
Old 6th Mar 2008, 5:24 am
try also using different versions of the upgrader tool. sometimes older version of the upgrade tool wont work with newer firmware (based on my observation).
Old 7th Mar 2008, 10:15 am
can you please tell me if you know what's the right firmware.. my player is mp4 3rd generation 8gb with fm and 1.8" display.. the chip is
AK1025 7K083AB 0KP
on board says 2002 02 18VER: A and B0-25002
and on screen says
BG999100-A-V0.0v W 071221/A5 and OEM-101C-NL-WD-HSVSI01
Old 7th Mar 2008, 10:48 pm
try this firmware http://rapidshare.com/files/97901552..._20070626_.bin
or http://rapidshare.com/files/97903123...b5KEY071126.fw
with this tool http://rapidshare.com/files/75514260...ility_4_12.rar
Old 9th Mar 2008, 11:05 am
i try to use mp3 player utility 4.12 but when i select any of the two files the program crashes with the message that it stopped working.. something i remembered is that when the player was wokring i had check the firmware version and it was 9.1.52
Old 10th Mar 2008, 3:52 am
try this http://rapidshare.com/files/76250376/ProdTool4_25.rar
Old 11th Mar 2008, 6:08 am
since the unsuccessful attempt with 4.12 the blue hourglass screen is gone and now it's just blank screen..
i managed to work mp3 player utility 3.06 but the two firmwares i used failed to install.. do you know if there is any other firmware i can use?
with 4.25 the firmware is installed and the player is recognized as a removable usb device but with no capacity. do i have to format it through windows? what's the next step?
thanks interuptor0 for your help!
blue screen with a sand glass in the middle of the screen jacko-2009 Dead Players 3 26th Jan 2009 12:36 am
froze up to an hour glass screen chrystal0925 Dead Players 7 4th Nov 2008 9:38 am
Stuck on hour glass kamalrohit Support and How To 1 14th Jan 2008 2:26 am
3rd gen mp4 stuck on hour glass???? patches22 Support and How To 1 23rd Aug 2007 4:56 am
MP 4 Player stuck on hour glass mikc67 Support and How To 9 1st Jul 2007 7:00 am
