Player not turning on. Unknown device ATJ2085W mp680-cl-v11
Old 15th Mar 2008, 6:20 am
Default Player not turning on. Unknown device ATJ2085W mp680-cl-v11
:cry: :cry:
I have a mp4 Player, Board Id- mp680-cl-v11 , Chip- ATJ2085W . Its firmware is damaged and it is not turning On. Computer is now showing Unknown Device .
I tried AdfuUpdate.inf from Windows Folder to run dead mp4 player as ADFU Recover Mode. But Windows does not take it and showing this messege
" The specified location does not contain information about your hardware". I am using windows XP service pack 2. What should I do now ? I Have Download
This Player's Firmware From www.s1mp3.net . But I Need Usb Driver For This Player .
Shezan
Bangladesh.
Old 15th Mar 2008, 7:18 am
you have to run windows vista to use the ADFU driver.
for win xp you have to search a different ADFU file or modify it
Old 16th Mar 2008, 4:17 am
Default Re: Usb Driver Help
gorib65,restart your computer.Then install the latest version of Mp3 Utilities that can be found at the download section.Then short again(if you have done already) the flash pins of your player.Then plug it on the computer then if asked for driver just use the RECOMMENDED option always and ignore the WINDOWS LOGO ERROR just continue.It should work now and your player will be on ADFU mode already.
chinese mp4 player unknown device in xp spodey Support and How To 6 2nd Dec 2009 10:01 am
Looking for Board Id - mp680-cl-v11 Chip - ATJ2085W gorib65 Firmware 1 14th Aug 2008 5:18 am
Dead player USb 2.0 ADFu and Unknown device mladen133 Dead Players 9 30th Jan 2008 3:36 am
Blue screen in mp4 player unknown device.... gabb9 Support and How To 7 25th Sep 2007 6:38 pm
Need Firmware FS66 [proc: ATJ2085W mb: MP680-CL-V11] Crossbr Dead Players 2 20th May 2007 6:52 pm
