help from turkey
Old 21st Mar 2008, 12:50 pm
Default help from turkey
:cry: no english .from turkey.
50, 60, written, test, never, one, become,
memory : samsung 649 k9g8go8uom
cpu : atj2093h
Old 22nd Mar 2008, 8:13 pm
Default Re: help from turkey
FCmitsss,look for the Board Id of your player and post it here.Have a look at here:
http://s1mp3.org/en/docs_hwspecs.php#boardid
Old 23rd Mar 2008, 2:39 pm
none bard id
Old 26th Mar 2008, 2:28 am
FCmitsss,every player has a Board Id.Have a look at your player again.Look for behind the LCD or at the pcb board of the buttons.
Old 27th Mar 2008, 11:29 pm
board id
h 06 09 1242 09 12 061205 b hb
Old 31st Mar 2008, 11:38 pm
it's too complicated for a board id.Okay the best for you to do now is stated as your player's RAM is atj2093H so it probably uses v9 firmware.Try all the version 9.xx.xx firmwares that can be found on the download section. Theres no way we can tell if which firmware will work at least you have to try them all.
Goodluck!!
