Dead or alive? :) Stucked in waiting state! :(
Old 26th Mar 2008, 6:41 am
Default Re: Dead or alive? :) Stucked in waiting state! :(
if you have the identical or same player you can use s1clone.Have a look at the site below for infos how to use it.
http://s1mp3.de/tools.s1clone.html
Good Luck!!
Old 26th Mar 2008, 10:19 am
Thanks for your advice and kind help! I will try and post the firmware when success...
My problem is the explorer cant identify the player..... The driver and the device manager see as ADFUU device, but nor the explorer...
Any idea?
Old 26th Mar 2008, 7:22 pm
if a player is in ADFU(recovery) mode it can't be detected on the explorer.
In the discription of s1clone:
"now connect the damaged player. therefor you have to bring it at least into ADFU mode (maybe you have to short-circuit the memory chip). take care you have the actions usb driver or, even better, the libusb/swan usb driver installed. finally write the extracted flash image and with some luck you will own another working device!"
Frequently Asked Questions
The application fails to run!
the application expects the "libusb0.dll" to be present either in the application path or inside window's "system32" folder. this dll is attached to the s1clone archive, inside the "usb_driver" folder. if not done already, please copy this file to the location where you have extracted "s1clone.exe" before. instead, you could also install the libusb driver which will automatically copy the needed dll to your windows system32 path.
What to do on the "Semaphore Timeout has expired" exception?
it seems this problem isn't caused by the player, but by the computer itself. some usb ports (maybe v1.1 ports), don't work properly with the libusb/swan driver. using another computer to clone the player may fix this problem.
Old 27th Mar 2008, 1:08 am
"if a player is in ADFU(recovery) mode it can't be detected on the explorer. "
but in the deadplayer recovery guide I have red that it should see in the explorer, because needed to format it...or something I misunderstood?
Thanks for your great help!
Other question: if I have a new player, can I make a backup of the firmware just in case?
And to publish here for the others
Old 31st Mar 2008, 11:57 pm
Yup absolutely misunderstood.What i mean is that if your player is in ADFU mode you can't access it as a REMOVABLE DRIVE.You can't format it cause its still in ADFU mode or RECOVERY MODE.Only the DEVICE MANAGER can see the ADFU.But if you have flashed a compatible firmware and it works for your player it shoould be detected in the computer as a REMOVABLE DRIVE,so thats the time you can format it.Got it buddy?
Yes you can use Wire's tools the s1fwx to extract firmware but only supports version 3.xx.xx firmwares and for v9 firmwares is still on development.
Wire's tools can be found here www.s1mp3.de
  #16 (permalink)
Old 1st Apr 2008, 12:08 am
I see, thanks for making it clear!
Dont you know with wich program could I backup , edit and restore the firmware of the 2,8" touch screen MP4?
I mean this type:
2,8 touch TFT with Rock chip
Thanks in advice!
  #17 (permalink)
Old 19th Apr 2008, 11:26 am
Hello Master!
I have one short question: I have the proper firmware in .bin file...BUT I cant upgrade with the "MP3 Player Upgrade Tool" because "player cant find"...because is in ADFU mode, so the explorer cant see...
Which program should I use to burn in the firmware?
The s1clon see, the player, but said cant proper file type... the s1fwx cant see the player neighter...
Thanks for your help in advice!
  #18 (permalink)
Old 19th Apr 2008, 11:30 am
Originally Posted by bulesz";p=&quot View Post
Hello Master!
I ment the nano clone NOT the touchplayer!
How to get my Sigmatel player in recover state? ammaoui Support and How To 0 21st Sep 2008 7:39 pm
Almost-dead X-Micro F510 1GB Player is now alive. F510 fw DL scancode Dead Players 0 5th Apr 2008 6:37 pm
still waiting for help ASIF320 Dead Players 0 20th Mar 2008 9:26 am
Mp3 dead, storage alive!! HELP!! RedFox Dead Players 3 3rd Apr 2007 5:40 pm
A dead player can be alive downloader99 Dead Players 1 3rd Apr 2006 1:57 am
