Dead or alive? :) Stucked in waiting state! :(
Old 25th Mar 2008, 4:06 pm
Default Dead or alive? :) Stucked in waiting state! :(
I have the 3rd gen Nano clone with 1,8 TFT and 3,8 GB.
So the battery went empty, and just pluged the usb cable (not connectet to the PC!) just the pure cable, the starting sand timer screen was appeared. And now stucked on that! Only that screen appears.
The PC not recognize as ADFUu just undefinided USB device.
I can turn on to the sandtimer, so its not totaly dead, just a Zombie...
? How can I reset this? I didnt hurt the firmware anyway, just formatted with the hacking removal method...and used for 2 days.
Please help me!
Old 26th Mar 2008, 12:41 am
bulesz,turn it on again and wait for about a minute if still the hourglass stuck,sad to say your player is simply as dead.Maybe in the charging thing damage the firmware on it.You know when you charge your player you should have to plug first the charger on a AC outlet along with the usb cable then last is plug it in on your player.
Follow the guide here:
http://www.mympxplayer.org/dead-play...ide-vt567.html
Old 26th Mar 2008, 1:02 am
Default Re: Dead or alive? :) Stucked in waiting state! :(
thanks for your reply!
So the proper charging method: Plug the cable to the PC or AC, and turon on the player with the switch (on the case, and NOT with the play button) and after plug the player to the cable?
Just to know at my next player...
Old 26th Mar 2008, 1:10 am
I could install the ADFUU driver, but not seen by the explorer? What should I do?
Old 26th Mar 2008, 1:16 am
almost players can be charge even if it is in power off.Yes the player would be the last to be connected.It's an "electronics way" thing to do.
Install the latest version of Mp3 Utilities.Then short again the pins(if you have done it already).If asked for ADFU driver always use the RECOMMENDED option.
Old 26th Mar 2008, 1:24 am
Thanks for the reply!
One more question, how could I know which player is this? i mean which firmware is needed? Its a Rock chipped item? or something else? What should I search on the firware site?
Many thanks!
Old 26th Mar 2008, 1:25 am
Open up your player and post whats in it here.
Old 26th Mar 2008, 1:35 am
those found:
AK1025
8A023AB
HYNIX
HY27UU08AG5M
TPCB 809AA
Old 26th Mar 2008, 2:23 am
Look for the BOARD ID of your player and post it here,have a look at the link below:
http://s1mp3.org/en/docs_hwspecs.php#boardid
Old 26th Mar 2008, 5:31 am
It is not a serious problem to get the fireware because I will have another player (the same) and I would copy its firmware to this sick one.
BUT, the windows explorer couldnt recognize it! In the device manager its an ADFUU device but I cant do anything with this!
I should nuke the pins (hardreset) and replay the install method?
How to get my Sigmatel player in recover state? ammaoui Support and How To 0 21st Sep 2008 7:39 pm
Almost-dead X-Micro F510 1GB Player is now alive. F510 fw DL scancode Dead Players 0 5th Apr 2008 6:37 pm
still waiting for help ASIF320 Dead Players 0 20th Mar 2008 9:26 am
Mp3 dead, storage alive!! HELP!! RedFox Dead Players 3 3rd Apr 2007 5:40 pm
A dead player can be alive downloader99 Dead Players 1 3rd Apr 2006 1:57 am
