-   -   Sunplus spmp 3052A firmware (http://mympx.org/forum/dead-players/40955-sunplus-spmp-3052a-firmware.html)
cheekeens 30th Mar 2008 6:58 am
I have this mp4 player 1gb flash with a slide panel. I actually bought it from cdrking.
it looks like this:
http://www.cdrking.com/images/produc...ers/sb0700.gif
http://www.cdrking.com/images/produc...ers/sb0703.gifhttp://www.cdrking.com/images/produc...ers/sb0701.gifhttp://www.cdrking.com/images/produc...ers/sb0702.gif
it has a blue screen background but it doesn't have fm radio, calendar, and time function. I've tried firmwares that i downloaded from this site but I ended up having a white screen or sometimes the power in on but the screen is still black.
can you guys tell me how to enable these features?
zenitraM 30th Mar 2008 8:42 am
Re: Sunplus spmp 3052A firmware
I've got the same one, it uses this firmware: http://zen.itram.es/files/PMP_DX_sku...background.rar
You can't enable FM, Calendar or Clock, as the player doesn't have onboard clock or FM radio, they just don't work. I haven't found any single compatible firmware that wasn't the original one..
cheekeens 30th Mar 2008 6:55 pm
Sad news, but anyway thank you very much for your reply.
Zulu007 1st Apr 2008 11:15 pm
I too have the same player but i still dont get that how to make the player to go in software mode or to make the player to detect as the camera to load the firmware in it.I have read the guide but didn't able to make it in camera mode ........... may be becasue my player is not showing anything just when i press the power button it show the green light and i have checked it completely on the hardware it is fine ,there is not hardware problem in it......it is just showing that it needs the firmware.
Beerzerk 2nd Apr 2008 11:02 am
Try to follow those steps, and download the tools in the guide.
http://www.mympxplayer.org/image-vp45504.html
Of course, I've seen the same type of PMP with Sisis processor and Sunplus processors, get into recovery mode in Sisis it's simples : press ESC while you connect the device on the computer, and Sunplus it's a combination of keys, in my case, it was A + OK.
cheekeens 2nd Apr 2008 9:35 pm
but anyway, is it still possible if i had someone add a fm or clock thing on the mp4 to be enable the clock and fm function?
Zulu007 3rd Apr 2008 2:16 am
The fm function is not only based on the software or the firmware ,if your mp4 have the FM-CHIP then you can change the software to add the fm function on the mp4 player.Other wise you have to put the FM-CHIP in the player and then use the right firmware for it and then FM will start to work
sakshamdhawan2 26th Feb 2009 1:38 am
I too bought one sunplus pmp from here
http://www.homeshop18.com/shop/u/y/p...lI_2-q_imedia-
its been one year now..it was working perfectly..but somehow yesterday when I was playing an nes game it crashed and now it does'nt even switch on.sometimes it does but crashes
I think I need to reload the firmware.WHEN IT WAS WORKING ,it had a blue background behind the menu.So plz tell which firmware is compatible.
thanks
Vasyaga 26th Feb 2009 6:33 am
I've just bought this one: http://www.dealextreme.com/details.dx/sku.1579
It has worked within 4 days and then have died.
I know how to switch it into programming mode (hold down 'M' or 'camera' key and plug USB cable) and I've already tried a bunch of firmwares. Chipset - SMP3052a hynix etc... But no results. I've backed up my original firmware, but I think that it's broken. When I am trying to re-load it into player - it freezes somewhere about 80%. I've tried to wait about 3 hours and no results.
All another firmwares gives a lot of bugs (reversed picture, screen blinking, no sound, shuffled buttons etc.)
Could anyone help me with that? I like this gadget, but I hate this problems :evil:
Zulu007 1st Mar 2009 11:40 am
Vasyaga
you can fix the original firmware if you have 80% of it.if your firmware carries the .bin files then you can change anything in the firmware or replace from other firmware but dont replace the (.bin) files.
