Problems with Pacific MP4
Old 6th Apr 2008, 7:10 pm
Default Problems with Pacific MP4
Hey there! I'm new here and I've got a big problem!
I have a fake Sony MP4, with FM, recorder and 2 GB, with mini SD card slot. It's also called "Pacific".
It worked fine for a while, but one day I dropped it on the floor and since then no more turning on... but when I plug in my PC, it is recognized and also make the recharge routine. Also, if I try to turn it on with USB plugged, works fine!! It's not working only using "unplugged" mode...
So I opened the player and checked the batterie and connector, but it's everything OK. I tried to update the firmware (the board said JS820B_V4.0_070720), but still not working. Instead, it made a downgrade... I had version 00.00.0003 and now it's 00.00.0000.
What should happened?? Does anyone knows what should I do to fix this thing? And how about the firmware? Any chance to find an up to date one?
Thanks a lot!
[]'s
Old 7th Apr 2008, 7:19 am
http://www.s1fw.com/ROCK2608-Chip/RK...S03200A-A.html
GOOD LUCK FOR YOU
Made in Shenzhen
Dead player
Old 7th Apr 2008, 4:56 pm
Originally Posted by s1fw";p=&quot View Post
http://www.s1fw.com/ROCK2608-Chip/RK2608-JS820-V4-0-070720--GANT29S03200A-A.html
GOOD LUCK FOR YOU
Hey there s1fw!
I tried this firmware, but didn't work... instead, I've got a white screen, so I had to hard reset the player and went back to 0000 version... btw, thanks!
Problems with new mp4 al pal Support and How To 4 5th Nov 2007 5:03 am
MP4 Problems mark2 Dead Players 18 2nd Feb 2007 11:01 pm
problems with vl-547 dp Support and How To 2 25th Sep 2006 10:47 pm
PTA. Has to much problems PTA Video related 5 19th Jul 2006 7:25 am
AMV 4.00 problems max2 Video related 10 1st Jul 2006 2:59 am
