Player stuck on locked.
Old 11th Apr 2008, 9:16 pm
Default Player stuck on locked.
A friends touch screen mp4 from www.tinydeal.com was upgraded with the latest firmware from that site, but now, the player works except you cannot do anything with it. It is stuck on "locked" (hold) so you cannot do anything or access the upgrade mode, ANY help is highly appreciated.
I have 2 weeks to fix it before they go away.
Thanks everybody.
Old 11th Apr 2008, 9:48 pm
Try pressing the button at the top of the player.
Old 12th Apr 2008, 6:10 am
i have the same problem, i tried pressing the button on/off of my mp4 player, but it didn't work. i tried to format it using the Windows XP CD format, but it didn't work. the mp4 player has no material problem, the problem began since i upgraded it using a wrong firmware.
Old 12th Apr 2008, 9:08 pm
hmm, this is really annoying.
Old 12th Apr 2008, 9:30 pm
What I mean is once you hold down the power on and it is on just press the power button down once.
Old 13th Apr 2008, 11:22 am
you said your mp4 player works; Enter the menu "setup" (from your mp4 player), select "onligne mode" then change "encrypted" to "multi disc"
-if your player does not work(dead) you have the same problem like me.
good luck
i-Digital Touch Screen 8GB MP3/MP4 player samsung flash keyboard locked, cant unlock! BDMK Support and How To 1 20th Jul 2009 4:20 am
Unlock a locked MP4 player d2dp Support and How To 7 19th Sep 2007 7:33 am
mp4 player stuck. vishnucr Dead Players 3 20th Apr 2007 7:52 pm
MP4 player locked w/blue screen and hourglass-pls help! technodummy Dead Players 10 20th Feb 2007 11:13 am
VOIP is locked. Need update it. Error in Mp4 player ganie17 Dead Players 1 15th Feb 2007 8:58 am
