Help with getting into adfu mode
Hi Everyone
i need help fixing my mp4 player i uploaded a custom firmware now its stuck at the hourglass screen ive got it open ive flicked the pins i once got it stuck on a black screen but nothing on computer. RIGHT NOW it is on hourglass its open but on device manager it is in Others devices called usb device with yellow exclamation all i need is help to get it into adfu mode and i can take it from there but can help if like PLZ HELP Thanks |
Re: Help with getting into adfu mode
moneybankz,what type of player do you have?Shorting again the pins will do the trick its quite random you need to do it a few times.And when asked for ADFU driver always use the RECOMMENDED option.
thanks for help spent 2 hours trying but still didnt come up and the battery broke off
thanks for the help zrock |
use other battery if you have an extra one.You can use any 3.6V or 3.7V Lithium-Ion cellphone battery.Take it easy don't feel the rush. :)
hi zrock
dont have another battery but can i connect the old one back on and how thanks |
moneybankz,if you have soldering skill just connect back the positive & negative wires of the battery to the positive & negative power terminal of your player.
WARNING: do not short-circuit the battery. |
hi
thanks for the help but i already did it and changed it adfu server but now i can find my firmware if you can help my player is a 2nd gen ipod nano thanks |
if you want the text in adfuupdate here it is:
[Version] Signature="$CHICAGO$" Class=USB ;ClassGUID=1181f4a0-f284-11d2-9068-00609797ea5a} provider=%MSFT% DriverVer=08/20/2004,2.0.0.0 LayoutFile=layout.inf [Manufacturer] %MfgName%=Upgrade [Upgrade] %USB\VID_10D6&PID_1160.DeviceDesc%=MDisk.install,U SB\VID_10D6&PID_8888 %USB\VID_10D6&PID_1160.DeviceDesc%=MDisk.install,U SB\VID_10D6&PID_ff51 %USB\VID_10D6&PID_1160.DeviceDesc%=MDisk.install,U SB\VID_10D6&PID_ff66 ;[PreCopySection] ;HKR,,NoSetupUI,,1 [DestinationDirs] umss.files = 10,System32\Drivers [MDisk.install] CopyFiles=umss.files AddReg=umss.addreg [MDisk.install.NT] CopyFiles=umss.files AddReg=umss.addreg [MDisk.install.NT.Services] Addservice = AdfuUd, 0x00000002, AdfuUd_AddService [AdfuUd_AddService] DisplayName = %USB\VID_10D6&PID_1160.DeviceDesc% ServiceType = 1 ; SERVICE_KERNEL_DRIVER StartType = 3 ; SERVICE_DEMAND_START ErrorControl = 1 ; SERVICE_ERROR_NORMAL ServiceBinary = %10%\System32\Drivers\AdfuUd.sys LoadOrderGroup = Base [umss.addreg] HKR,,DevLoader,,*ntkern HKR,,NTMPDriver,,AdfuUd.SYS [umss.files] AdfuUd.sys [SourceDisksNames] 1000 = "USB Mass Storage Device",,, [SourceDisksFiles] AdfuUd.SYS = 1000 ;---------------------------------------------------------------; [Strings] MSFT="MP3 Player" MfgName="MP3 Player" USB\VID_10D6&PID_1160.DeviceDesc="USB 2.0 (FS) ADFU Device" thanks |
| All times are GMT -7. The time now is 8:01 pm. |
