RockChip Like iTouch, Blank White Screen!!! HELP PLEASE!
http://img.diytrade.com/cdimg/538819...y_with_MP4.jpg
Hi, I ordered a rockchip mp4 player that looks like an itouch. I turn it on, or plug it into my computer, but all that shows up is a blank white screen. The usb port works, theres just no picture! (Blank white screen). PLEASE HELP ME!!!!!!! THANKS!!! |
Re: RockChip Like iTouch, Blank White Screen!!! HELP PLEASE!
Thanks for the reply. I already found that forum and it didnt work out to well. My main problem is, is that i cant get my rockchip into recovery mode. Do you know how i can do that?
Thanks! |
Hi,
Thanks so much for that link to get the firmware. Theres only one problem; I dont know how to check what the numbers, that you have to search for. For example, i cant find AK1025. I opened up the player, but i just cant find any numbers similar to those. Can you help me find the correct firmware? Thanks! |
Have you tried the reset button hole?
You may have to resort to hard recovery, here is a guide to help you:- http://myfreefilehosting.com/f/a6ae653b62_0.15MB Here is a long thread on MP4nation for this type of player which may also help you:- http://www.mp4nation.net/forum/viewt...&sd=a&start=60 |
Hello. I also have a similar MP4 player with same problem - blanc screen and thats all. Anyone can help?
| All times are GMT -7. The time now is 3:20 am. |
