I need help. Zap SR100 (Teclast c260 copy)
Old 27th Apr 2008, 4:47 pm
Default I need help. Zap SR100 (Teclast c260 copy)
First of all i am sorry. I am almost sure that the answere to my problem is in this forum allready. But since there is no search function that i can find to scan specific topics i had to start scrolling trough every post in here, and it got boring really quick after the first 100 posts... Considering there is Over 5000000000000 posts here!
My problem:
I now got a completely white screen on my Zap SR100 (Teclast c260 copy).
I am unable to get it to show up as a RockUSB device to flash it even tho iv spent the last 5 hours holding down every button connecting it to the pc 50 times each. Im ready to do the last resort ( shorting circets ) however i cant figure out how to open it? No screwes and no edges or holes to use for bending....
Edit: In the end i was able to open it. Took some doing and broken finger nails but it worked. Now the question is what i need to circit to lol
Sorry. This ended up being a useless topic.. Feel free to delete.
Old 27th Apr 2008, 7:07 pm
Default Re: I need help. Zap SR100 (Teclast c260 copy)
Hi Hitomi,
Welcome to the board.
Your post is fine, it's not "useless" as you mentioned .
You mentioned you couldn't find the search. On the left hand side menu bar, there is a "Search Site" link which you can then use to search this site.
Can you post some images of the inside of your player please?
Old 9th Sep 2008, 2:59 pm
Originally Posted by admin";p=&quot View Post
Hi Hitomi,
I can't upgrade my Teclast C260 mp4 player. Could not get it into upgrade mode. No reasonable solution I found on this site. It's useless...definetly
Old 10th Sep 2008, 3:02 am
And what exactly is your problem?
Is your player dead? etc.
Old 10th Sep 2008, 8:31 am
Yes, kind of that. Only a white screen is shown all the time. :|
Old 10th Sep 2008, 11:43 am
Do you have the original, copied from your player, FW?
Old 11th Sep 2008, 11:55 am
No, unfortunately. But I've found on the site 3 versions of firmware for Teclast C260.
The problem is that I could not bring player in Upgrade mode. I've tried 3 times (SW rest in upgrade mode) with different versions (wrong versions of firmware) and now I can't upgrade again. (I think that these versions are the same as the original).
I opened it and I tried to bring it in upgrade mode in HW mode and the result is the same. Neither SW mode nor HW mode helped me to bring player in upgrade mode after these 3 tries.
Old 11th Sep 2008, 12:00 pm
I posted also on another threads but no one gave me an answer.
Here is on of them.
http://www.mympxplayer.org/viewtopic.php?p=52089#52089
Picture of my player:
Except that mine is in English, but that doesn't matter. The software shown on the picture and the model of my player is like this.
Old 11th Sep 2008, 10:58 pm
Have you tried this software?
http://www.mp4nation.net/downloads/s...UPGRADEKIT.rar
Old 12th Sep 2008, 4:33 am
Please follow this thread for help.
http://www.mympxplayer.org/rockchip-...de-vt6686.html
The SFLOUPGRADEKIT will NOT work with this player, it is for RK27xx series players only.
The Teclast clone is a RK2608 player
Teclast C260 usb problems fu4f043j9g Support and How To 2 3rd May 2009 4:28 am
New firmware for teclast c260 clone? niel68 General Discussion 4 20th Jan 2009 1:45 pm
Teclast c260 clone mueslee Dead Players 0 24th Sep 2007 4:25 pm
What are the advantages/disadvantages of Teclast C260? Darklink General Discussion 1 3rd Sep 2007 1:49 pm
Teclast C260 Pocket_Nano General Discussion 5 13th Feb 2007 10:37 am
