Need Lotus (3.35.7) Firmware T_T
Old 4th May 2008, 5:23 am
Default Need Lotus (3.35.7) Firmware T_T
Hi, I'm ZShock, and I'm new. This is what happent to me by beeing stupid! Please, excuse my bad english, my 1st language is spanish.
Well, here comes the problem. I have a MP4, exactly like this picture uploaded by someone
http://www.mympxplayer.org/image-full-asp125.html
The problems is, I upgraded with the incorrect upgrade and I didn't find MY Lotus Flower Firmware. Currently, I used a firmware, and seemed to work, but instead of opening the volume menu, it sets the volume down. So, in fact, my problem is, I need the Lotus Flower Firmware 3.5.37, if possible.
Thanks for your time, ZShock.
Old 4th May 2008, 8:44 pm
ZShock,have a look at here.Let me know if you have questions.
http://s1mp3.org/en/docs_advanceduguide.php#fixbtn
Old 5th May 2008, 10:09 am
Default Re: Need Lotus (3.35.7) Firmware T_T
Thanks a lot man, but I didn't solve the problem xD. Before you could answer I installed another one. This has all the functions, but it has too high contrast (white screen), and is horizontally inverted.
The question is: is harder to fix contrast + invert, or volumen menu?
Old 9th May 2008, 2:09 am
To fix contrast use the FirmwareModify Tool it can be found here:
http://www.divshare.com/download/1633736-5f3
For the "horizontally inverted" problem edit your firmware using s1res it can be found here:
http://www.divshare.com/download/1633858-72c
And for the volume menu problem, follow the link on my first post.
Please read & understand those things.
Good Luck!!
Old 10th May 2008, 8:26 am
Well, it doesn't turn on O_o
When I try to revive it, short circuit and everything, it's detected as "actions usb 2.0 (HS) WinUSB device", when I need an ADFU.
- Edit
Well, I don't know how, but it is an ADFU again, but Upgrade Tool seems to doesn't reconogize it...
- Edit 2
Ok, I think it's fully dead now LOL. I used the stupid Product Tools (http://www.mympxplayer.org/product-t...419-df234.html), and now my MP4 is stacked in the start clock screen... Anyway to fix this?
Old 11th May 2008, 4:11 am
ZShock,repeat again the "short ciruit" thing.Its quite time consuming for some players you may have to do it a few times.
Have a look at here for the upgrade tool.
http://www.mympxplayer.org/recommend...es-vt2559.html
