EM2802A thomson player. Issue with connection to USB
Old 12th Jun 2008, 2:52 am
Default EM2802A thomson player. Issue with connection to USB
Hi,
I'm new here , so let me first say hallo to everybody.
When I connect my mp3 to PC via USB cable, XP detect it for couple of seconds, than it can not seed for another couple of seconds, and it continues like that for ages. Have you got any idea how to make XP to see the player connected to USB?
The second issue is "profiling requires 1MB of free space" but that I hope I can fix with one of the guides found on this site, thanks.
It was blocked already once , I could not even switch it on , but pressing reset button made it work properly.
Many thanks for your help,
Regards,
Marcin
Old 12th Jun 2008, 1:52 pm
Hi ambaran,
I think the problem with your player connecting to your computer might be with the USB CABLE. That's been a problem for a few members in the past. So, if you can, get another USB CABLE and see if that works.
Wistar Thomson A1 Mp4 Player schlockmaster Support and How To 0 22nd May 2008 2:41 pm
Battery issue on new player Old Red Support and How To 5 13th May 2008 7:10 pm
Dead Thomson EM2601 MC_Kejml Dead Players 0 22nd Mar 2008 4:21 am
thomson sigma mp4 Siemion Dead Players 6 6th Dec 2007 12:43 pm
PC not detecting USB Connection JamaicanGambit Support and How To 5 10th Apr 2007 5:15 am
