[solved] what is important about firmware?
Old 20th Jun 2008, 10:41 pm
Default [solved] what is important about firmware?
would anybdy tell me what is important about firmware version?
I've my chinese mp4 player with the firmware
DX 91008
CM 70038
ACT V- 9.1.52
should i use any firmware with the mentioned "ACT" or should i consider the rest of the information?
Old 21st Jun 2008, 8:37 am
S1 MP3 PLAYER firmware version:
FLASH different versions of key support
V9.0.50: support for Samsung, Toshiba FLASH
V9.1.51: support for Samsung, Toshiba, Micron and other FLASH
V9.1.52: support for Samsung, Toshiba, Micron and modern UU \ UT FLASH (such as: HY27UT084G, HY27UU084G
High-down version compatible, as can be V9.1.52 firmware upgrade V9.1.51
Low-brush version of the high version, there will be repeatedly re-starting at the resumption mode
ACT is the acronym ACTION, a Chinese chip company
YOUR FIRMWARE:
http://www.s1fw.com/Actions-AK102X/A...-20080315.html
Made in Shenzhen
Dead player
Old 23rd Jun 2008, 9:42 pm
Thnx VVVVVVVVV much.u have solved a great problem of mine.
keep up the good work buddy.
Old 17th Jul 2008, 11:43 am
Default Re: [solved] what is important about firmware?
hi.
i downloaded ur mentioned firmware that is
DX 90018
CM 70038
ACT v-9.1.52
but it does not worked.when i start upgrading the firmware it shows the message 'invalid firmware file selected'.am sure about my firmware version.
plz help me.
VERY VERY IMPORTANT NIKMANIA Support and How To 0 23rd May 2009 3:29 am
[SOLVED] need firmware for AK1025 fleming Firmware 1 3rd May 2008 9:39 am
[Solved]Updating my Firmware PLEASE HElP! ZiggyFlavel Support and How To 5 1st Oct 2006 9:01 pm
[solved]when i add my pic in firmware...... aillez Support and How To 14 6th Jul 2006 2:56 pm
[solved] Firmware for MP4 1,8" NietzschE Support and How To 0 29th May 2006 7:17 pm
