Mp3 Upgrade tools can't connect to device USB ADFU. Help me!
Old 15th Jul 2008, 8:44 pm
Default Mp3 Upgrade tools can't connect to device USB ADFU. Help me!
I have mp3 player SONY, no FM. Because i up firmware error. Now PC detected as a device USB ADFU. But Mp3 Upgrade tools can't connect to device USB ADFU. Help me!
Old 25th Jul 2008, 6:31 am
Try other version of uttilities they are stupid someway
Old 25th Jul 2008, 10:56 pm
napa mp3 is dead pls help
Old 14th Aug 2008, 4:31 pm
maadurga... you have to put more INFORMATION here... as well Read the DEAD RECOVERY GUIDE...
Old 25th Aug 2008, 9:38 pm
I try any vesion mp3 Player Unitities. But my player die also. Help me
Old 4th Sep 2008, 4:14 am
use this
http://rapidshare.com/files/76250376/ProdTool4_25.rar
Old 6th Sep 2008, 5:53 am
Default HOW TO FIX CONNECTION FOR Mp3 device USB ADFU.
For all owners that has Chinese units that your computers can not recognize do the following and your computer will be able to ID the unit:
If using Windows XP
Go to stat
Control panel
Regional and Language
Language
Click on Install files for East Asian languages
after go to Advance and select Chinese (Taiwan)
Do the same on the tap for Regional Option
Reboot
attach your devise and it will show on your "My Computer"
try to use MP Player Utilities 1.46 and 3.68
The old utilities can see your drive better than the new one...
Keep in mind to reboot your computer after every change or click F5 in the folder of My Computer...as it takes time for the computer to read the changes
I hope this will help many of you.
After you fix your unit go back and select your local language.
ADFU device to working... How? Biostem Dead Players 0 5th Dec 2007 5:07 am
Usb adfu device driver pls techkarl Dead Players 2 7th Oct 2007 9:08 am
Mp4 is reconized as UNKNOWN DEVICE instead of ADFU or USB jiggio Dead Players 2 18th Feb 2007 5:37 pm
If you run MP3 Disk Upgrade Tools, will kill your player Dean786 Mods and Themes 5 31st Dec 2006 3:37 am
MP4 Player shows as 'USB DEVICE' not 'ADFU SERVER DEVICE' gregthomas02 Dead Players 5 18th Jun 2006 4:56 pm
