Invalid firmware
Old 19th Jul 2008, 1:28 am
Default Invalid firmware
i downloaded ur mentioned firmware that is
DX 90018
CM 70038
ACT v-9.1.52
but it does not worked.when i start upgrading the firmware it shows the message 'invalid firmware file selected'.am sure about my firmware version.
plz help me.
Old 25th Jul 2008, 6:28 am
Try using other version of uttilities... sometimes they get mad and write stupid errors =)
Old 4th Aug 2008, 9:51 pm
PLZ upload the above firmware.i've got deleted it somehow.thnx.
Old 6th Aug 2008, 3:19 am
you have to search for your procesor ID, then find trhe right software
Old 14th Aug 2008, 1:41 am
I've mentioned my firmware version.that is
CM70038
ACT 9.1.52
plz help me not able to fing it anywhere.thnx.
Old 14th Aug 2008, 2:15 am
Default Re: Invalid firmware
I have the same error, but with another MP4 (Ipod Nano clone). All firmwares I have tried give me "Invalid Upgrade Firmware Error." I have tried 4 versions of the software so far... do you suggest any specific version?
http://mp4.itram.es/wiki
Old 14th Aug 2008, 5:58 am
http://www.s1fw.com/Actions-AK102X/A...-20080315.html
GOOD LUCK
Solution:
1, drivers not to view the drive mode, FS? HS?
2, for computer operation, and upgrade tool set, the ban on the use of production tools
Made in Shenzhen
Dead player
Old 14th Aug 2008, 2:11 pm
Originally Posted by s1fw";p=&quot View Post
Solution:
Well, thank you for the solution, but.. well, I don't understand what are you trying to explain. The first one is to select the correct driver (FS/HS), but the second one.. production tools? What do you mean?
Old 14th Aug 2008, 4:29 pm
Means you have to unnistall your Upgrade uttilities and download other version and try it with it... understand ?
like MP4 uttilities 4.0 or 3.7 or whatever.. just try another version... sometimes it gets mad
Invalid Firmware ngaia Dead Players 0 3rd Apr 2007 4:24 am
Invalid Upgrade Firmware File! Sumo-Santa Support and How To 13 8th Oct 2006 2:22 am
Your invalid firmware Wu Support and How To 1 21st Jul 2006 8:30 pm
"Invalid Firmware upgrade file" error Moose Support and How To 1 16th Jun 2006 12:49 pm
"invalid upgrade firmware file" AoD Dead Players 8 16th Jun 2006 9:11 am
