player does not turn on. Plugged in it runs normally
hi; i own a chinese sony (1 GB w/ 1 mp Camera) and have a problem. It simply does not turn on. But when i plug in the usb cable it runs normally - until i start a game/video or mp3 :roll: when the sound starts to play the screen start to blink and die afterwards. To turn the player back on i have to unplug and plug the usb cable again. Thanks in advance.
and here is a photo of it : [web:8e8c5b1ffc]http://listings.auction.ph/Digital+Electronics+Games/Digital+Camera/Sony+MP4+Video+TV+out+Cam+1GB/id-11062736[/web:8e8c5b1ffc] |
Hi mymoonica,
Has this problem ALWAYS happened or has it only started happening recently? How long have you had your player? Are you able to get a hold of the seller and get an exchange? That might be the easier option. It seems your player isn't hold it's charge in the battery so I suspect there's something hardware specifically wrong with your player and would be easier if you get a replacement. |
thanks for the reply. The problem started recently. Its most likely because of the battery as it doent hold the charge. There is no seller as it is a present from a friend of mine that went to China. When its connected to the computer, it works just fine. I wonder if just a battery replacement would do wonders? :)
Yeh, sounds like a battery problem.
You can try to open your player and have a look at the soldering as there's been reports that the soldering on some of these players are rather 'dodgy' and not the best of works. |
| All times are GMT -7. The time now is 4:14 am. |
