Dead Player help required...
Old 17th Aug 2008, 3:46 am
Default Dead Player help required...
my player is with sunplus SPMP3052A-HL171
0747
M17A334
And the motherboard says PMP-703D-10.00
FX-MRU 94V-0E302652
another Chip hynix KOR
HY24UT088G2M
TPCB 751A
and on the front its written sony V-95
its with camera and mic
the problem is it do not start up
when i press the power switch a blue LED is on the goes off when i press the LED goes off when i unpress the power switch
with these some lines come on the LCD
its detected with when i press M key and insert the cable
then i have tried the FRM pro 1.1.9b tool
i can get the images from A, and firmware
But when i try for program all then ISP
it says
Check ISP core Success
Judge Burn size Success
Format Flash Success
Update RSV
Read verify error:
3050ABin0.bin
Program All Fail
Fail
FRM_READ_DIFFERENT_ERROR(32)-!
how could i fix it
please help me
thanks in advance...
Old 24th Sep 2008, 2:06 am
Default Re: Dead Player help required...
read this topic it would really help you...
http://www.mympxplayer.org/dead-pmp-...te-vt9087.html
Firmware ATJ2091N Required for china mp4 player hafeezu Firmware 0 4th Dec 2009 6:48 am
MP4 Player clone - operators instructions required CLUBSPORT999 Support and How To 3 18th Apr 2009 9:05 pm
New player, various questions and help required v3 Support and How To 6 29th Jan 2009 2:19 pm
Firmware required raykay3 Firmware 0 25th Dec 2008 4:19 pm
non urgent help required please goldenballs Support and How To 1 3rd Aug 2006 1:45 pm
