-   -   RockCHip based player went blank (http://mympx.org/forum/dead-players/42094-rockchip-based-player-went-blank.html)
bo_lek 1st Sep 2008 4:12 am
Hi,
here's my story.
I bought a player on ebay. Exactly the same as here
http://www.mympxplayer.org/rockchip-...219-df895.html
It froze so I switched it off. Now it won't switch on.
The screen is blank.
It is detected by pc.
I can see the large partition.
Luckily I copied the firmware :)
Bad news is that I can't upload the firmware back to the player as I don't see the hidden partition anymore :(
I downloaded all the tools available here and I am stuck :(
I really hope you can help me to solve this issue and bring my player back to life :)
Could anyone guide me in the right direction please.
Many thanks in advance.
makd511 2nd Sep 2008 10:35 pm
hi
sorry, i saw this a couple of days ago but forgot to post
have you sorted it yet
there maybe a way to get t back .. will be a way
are you on an xp machine
download these files
http://www.mp4nation.net/downloads/s...UPGRADEKIT.rar
now this is all for another player but what we need to do is get the partition active again, once doe we can copy back your originals
there is a small program in the download called RK27DM.exe, run it and then connect the player, it should recognise it, if so the button with and underscored U will light up,
click the file browser button and select the tl50.rkw file in the download
click the button with the U ont it
now several popups will popup, click Y on all
now during this you may be asked for drivers, point windows to the drivers in the download and use them,
all being well it will recreate the partition with the firmware chosen
now load the teclast.sys file onto the main memory and reconnect the player, partition shuld show up, now copy back your original files
sorry this is rushed, post if its all gibberish
bo_lek 3rd Sep 2008 12:50 am
Re: RockCHip based player went blank
makd511 , thank you thank you thank you :!:
It's back again.
I started to remove the screws :wink: then I saw Your reply.
It worked like a charm :)
Thank you again :!:
makd511 3rd Sep 2008 3:01 am
excellent, i will have to write all these routines down in much clearer fasion so i can copy and paste it ewhen ever needed
sorry about the rushed post, but glad it all worked for you
cheers
jarr 3rd Oct 2008 12:49 pm
Sorry mistake
