-   -   my mp5 sunplus dont reconize the bettery charger (http://mympx.org/forum/dead-players/42098-my-mp5-sunplus-dont-reconize-bettery-charger.html)
sid2512 2nd Sep 2008 1:40 am
hello
before i charged my mp5 sunplus 3050/3052A,since yesterday i leave it for charching,and when i comme back to take my mp5,ifound it off ,that is not in usual ,battery charged ,i used it ,but when i tryed to turn off i cant, better empty,it stay looping betwen turn off and turn on, i tryed to charge battery ,it dont show me the screen that i sow it before ,but no thing black screen,even the orange lamp stay off ,before it was on when i plug in the battery charger,and green when i unplug the battery charger. by the way i tryed to extract or upgrade the firmware but no thin ,my pc dont reconize my mp5 as device, it reconize as drive I and H.
THINKS.
Groovy 3rd Sep 2008 1:16 pm
1.If it is recognised as two devices you need to fowlow some steps to repair that in here:
http://www.mympxplayer.org/how-to-re...ck-vt2400.html.
2.Black screen is strange... Does your mp5 have a reset button or a connectable battery that you can put off and back there to reset your player ?
3. seems it is confused someway... try what i said and if not working wire here... we will alk about what next.. Dont yet try to repair your firmware and if read all the articles about it... dont upload any new !
also look for forums of your provider to search if no1 has the same problem...
sid2512 8th Sep 2008 2:11 am
hello,
thanks to answer me
yes i have a reset button and connectable battery wich indicate 5V ,i had oppen it the chips is 3052A .
now when i plug the battery charger the mp5 stay on
i can use it now see movie or play game. but no indication of battery charging on screen the battery seem to be full,and when i unplug the charger the mp5 turn off.and if i try to turn it on puching button as before no thing. i did not tryed to remove memory hack because i had not probleme to copy file and delete.
after that now i had cut a battery from mp5 in order
to buy new one,i plug a charger the mp5 turn on with out battery maby that is the probleme if not the mp5 is half died ,i will use it only at home.
Zulu007 8th Sep 2008 12:01 pm
your mp4 has no problems at all just you have to change the battery.And yes no matter your mp4 is have the battery or not if you plug in the charger or the usb cable attached with the computer ,the mp4 will power on.It happens with all the mp4 and even to mp3 too so that is not a problem at all.
interuptor0 8th Sep 2008 6:25 pm
battery problem, replace battery
sid2512 9th Sep 2008 12:42 am
hello,
thanks for all, that is a good news,i'll do this soon, i'll keep you informed.
sid2512 13th Sep 2008 1:17 am
hello,now my mp5 sunplus 3052A is died.
black screen and i can't upgrade firmware ,my pc do not detect it ,the battery charger too.
and i tryed adfu method no thing, tryed to find combination of button like ok+a or esc or down
i tryed al combination but black screen.
Zulu007 13th Sep 2008 12:19 pm
can you give some pic of the inner of your mp4 and it is not possible that your player got dead by just connecting it with the battery
sid2512 14th Sep 2008 1:30 am
my mp5 resemble to this:
http://www.dealextreme.com/feedbacks...u.9504~id.5882
sid2512 16th Sep 2008 2:26 am
now and after a lot of attempt of shorting circuit a chip windows xp detect matérial but dont reconize or dont foun driver, unknown matérial.
screen is white.
