Need firmware for Shuffle clip clone 1GB
Old 7th Sep 2008, 11:57 am
Default Need firmware for Shuffle clip clone 1GB
Hi,
I need firmware for Shuffle clip clone 1GB, which is dead when it arrived. It has STMP35xx chip. This is exactly iPOD shuffle 2nd generation clip clone. It does not have any LED display. Tried various firmwares for SigmaTel STMP35xx chip from Internet by spending more than one week, but still unable to start this Shuffle clip clone 1GB.
Please send the link of firmware to download for this player.
Thanks in advance.
Old 7th Sep 2008, 5:31 pm
http://www.s1fw.com/Tools/Simatel-SM...-in-china.html
GOOD LUCK
Made in Shenzhen
Dead player
Old 8th Sep 2008, 10:53 am
Default Re: Need firmware for Shuffle clip clone 1GB
No. It did not work. The firmware location you provided is 002.611.300. I was able to flash the player. But only it succeed to make it a mass storage device. It did not show power up led light. Also I could not copy any music file onto it. It showed I-O error.
FYI: I have already tried below SMTPxx firmware versions for this player. But I could not start running MP3 music.
880.267.409
885.111.506
1212.020.040
002.511.342
880.107.327
880.107.329
2620.1121.001
The closest was firmware 2620.1121.001, with which I was able to copy music files. LED was blinking (but very dim), but music never played through headphone jack. Only I could able to play music through Windows Media Player after connecting USB port. Player was able to decode MP3 files and sent to WMP for playing.
Any help will be highly appreciated. Just to let you know this 1 GB generic shuffle clip clone with no display screen, no FM, no recording options.
Old 19th Jan 2010, 9:21 am
Default Did you ever succeed?
Hi Phili123
Did you ever succeed in finding the correct firmware for this?
As far as I can tell, my player has a AU3152 from ::: ALCOR MICRO, CORP. :::. This is different from what you quoted but suspect this may just be rebranding. My specs are identical to those of the player you mentioned and I have the same symptoms alas.
If you have any suggestions, much thanks
Dead Shuffle 2g Clone tripad Dead Players 8 16th Apr 2009 6:26 am
Problems with 1GB iPod Shuffle Clone Clip MP3 Player nzer_4_lyf Support and How To 3 19th Dec 2007 12:16 pm
ipod shuffle clone serious problem technologue Dead Players 10 17th Sep 2007 7:12 am
Instructions for iPod 2nd Generation Shuffle clone? RowMan Support and How To 5 1st Jun 2007 12:34 am
Shuffle Clone.. need help saurobr General Discussion - Uxcell.com 8 24th Mar 2007 2:56 pm
