rockchip rk2706 more than dead...
Old 9th Sep 2008, 1:31 am
Originally Posted by hiramusthafa";p=&quot View Post
pls yr guide line send me my email: hiramusthafa@gmail.com
please start your own thread and give as much details as you can about the player in order to get the right help
thanks
Old 9th Sep 2008, 6:21 am
Originally Posted by makd511";p=&quot View Post
hi
Originally Posted by beenchee";p=&quot View Post
hey...
this is the player http://img0.chinavasion.com/images/c...118-6-rngl.JPG
when windows not install the drivers, there's also no boot letter who gives me access to the player folders (
if the player in the link is he one then this is NOT a 2706 player at all and there is no hidden partition
you are another victim of the onda vx858 clone player debacle
are you sure that is the correct player, does your player sort music by album, artist etc and do a "medialib" update after adding new music etc
what does the settings screen say about the player
looks to me like it is not an 2706 player at all and this is why rkusb tag wont work
@makd511
the player i linked looks like my player. my player had have an hidden partition before it died and he has sorted musik by album, artist etc. and did medialib update after adding new music.
Old 9th Sep 2008, 7:29 am
Default Re: rockchip rk2706 more than dead...
beenchee,
try this software
http://www.mp4nation.net/downloads/s...UPGRADEKIT.rar
It helped me. Maybe it'll work in your case too.
1. Start the program
2. Choose the firmware (the one attached)
3. Connect the player
4. Click the button with U
5. Then just confirm several times.
If it works your player should be visible in windows as a new drive.
If so then
1. Copy teclast.sys to the player
2. Disconnect it
3. Connect again. You should be able to see the hidden partition.
4. Copy over your original firmware.
5. Disconnect the player
6. Switch it on.
Let us know if this works.
Good luck
PS
Inspiration makd511 in this thread
http://www.mympxplayer.org/rockchip-...k-vt11084.html
Old 10th Sep 2008, 7:49 am
@bo_lek
at first...thank you the followed your instruction from point 1-5, although i clicked the R button, and now the player is visible in windows again ...so far, so good
but the next step to reactivate the hidden partition failed, although i followed your instructions no hidden partition is shown...
futher, i opend the rk27dm software and choose tl-t50.rkw file, pushed the r-button and he started to do something. the operation seemed succsessful (without knowing what i has done). but nevertheless, the hidden partition doesen't appear
Old 10th Sep 2008, 7:53 am
by the way...the player, former shown as rockshipxxx, is now shown as teclast digital player.
  #16 (permalink)
Old 10th Sep 2008, 8:20 am
Ok, so far so good
It is visible vas teclast device as you used their software. I'm kind of lost you don't see the hidden partition after copying the teclast.sys file.
It worked in my case.
  #17 (permalink)
Old 10th Sep 2008, 8:27 am
hmm...another instruction?...
is it easier doin by macintosh? I've got an mac, g4, too...
  #18 (permalink)
Old 10th Sep 2008, 11:17 am
Hmm, I checked the original instructions by makd511 and he actually mentioned the button with U.
So let's try to run the software this time with U button.
After successful completion copy the teclast.sys file, disconnect and connect again, and let's pray you see the hidden partition
BTW you've got the original FW, haven't you?
  #19 (permalink)
Old 10th Sep 2008, 12:30 pm
did you get promted at any point to install new drivers by windows
sometimes the U button does not activate, i have pressed ther R button before and it failed, but when i disconnected and then reconnected the computer asked for new drivers, i pointed it to the rockchip drivers and the partition was there, reformatted it and all was well
  #20 (permalink)
Old 13th Sep 2008, 1:05 am
soo...here i'am
this morning, i opened my mp4 player and i saw an a ship named rockchip 2706. so, can i be sure that my player is based on a rockchip, can't i?
i think to install the tl-t50.rkw was the wrong way, wasn't it?
when i connect my player to the pc, there is still only found one boot-letter, not the hidden partition it seems, that windows has the right usb-drivers and it didn't asked me to install any drivers again. when i connect the player, the screen went white...but nothing more
please help me find my hidden partition to install the firmware again
Strange Problem with my Rockchip RK2706... zirus Support and How To 0 6th Jun 2009 5:40 pm
rockchip rk2706 ... dead Lor3nzzo Dead Players 2 21st Apr 2009 11:55 am
rockchip rk2706 dead. plz hlp mohitanand Dead Players 7 24th Feb 2009 6:16 am
Rockchip RK2706 VX747 clone bug over Support and How To 3 26th Dec 2008 2:09 am
Rockchip RK2706 Datasheet David99 General Discussion 0 17th Aug 2008 1:07 pm
