rockchip rk2706 more than dead...
  #31 (permalink)
Old 14th Sep 2008, 12:27 am
Default Re: rockchip rk2706 more than dead...
ok...i tried every step you instructed, but everywhere, theres something with a wrong "code". thats all i can read in this hieroglyphs
  #32 (permalink)
Old 14th Sep 2008, 5:42 am
But did you get the RockUsb icon?
Yes I know, it isn't easy using the chinese software, But if you can get into RockUsb mode you should be able to recover your player.
  #33 (permalink)
Old 15th Sep 2008, 9:20 am
ok..i tired again and again...but no success
have anyone an idea how i can get access to player again...to the main folder?? no boot letter appears
  #34 (permalink)
Old 15th Sep 2008, 9:36 am
The RK27DM.exe (Rockchip Device Manager) should recreate the main folder for you by pressing the "R" button.
Are you sure you didn't already repair it?, remember you need to right click it in windows explorer and format it before you can use it.
  #35 (permalink)
Old 15th Sep 2008, 9:39 am
no way with RK27DM.exe. it faild again and again. i don't know if i repaired id or not. the problem is, that i can'T see anything in the explorer
  #36 (permalink)
Old 15th Sep 2008, 9:47 am
ok..little brainstorm....at the time i had access to the main folder, i copied the setup.rkw file (which is attatched in the sfloupgradekid) to the main folder, restarted the player and since THEN i hadn't have access to the player...
  #37 (permalink)
Old 15th Sep 2008, 1:05 pm
setup.rkw is no good for you, this will NOT work for you
we need 2 drives
please connect you player to your computer
wait for it to connect
go to safely remove hardware and double click
now take a screen print of the window that pops up and upload it for us to see
  #38 (permalink)
Old 18th Sep 2008, 5:54 am
  #39 (permalink)
Old 18th Sep 2008, 6:09 am
Originally Posted by beenchee";p=&quot View Post
http://www.bilder-hochladen.net/file...-1-jpg-nb.html
  #40 (permalink)
Old 18th Sep 2008, 6:13 am
Strange Problem with my Rockchip RK2706... zirus Support and How To 0 6th Jun 2009 5:40 pm
rockchip rk2706 ... dead Lor3nzzo Dead Players 2 21st Apr 2009 11:55 am
rockchip rk2706 dead. plz hlp mohitanand Dead Players 7 24th Feb 2009 6:16 am
Rockchip RK2706 VX747 clone bug over Support and How To 3 26th Dec 2008 2:09 am
Rockchip RK2706 Datasheet David99 General Discussion 0 17th Aug 2008 1:07 pm
