rockchip rk2706 more than dead...
Old 8th Sep 2008, 11:17 am
Default rockchip rk2706 more than dead...
hey,
at first...sorry for my bad english. i'm from german and it's a coupleof years ago since i've used my english
i'Ve got a problem with my mp4 player (named in the topic). it died when i changed background. but a new firmware is not the problem. at first, i only saw one partition with 8gb, not the hidden for the firmware. i tried it with rkusb.tag, but no reaction. then, i copied the setup.rkw in the main folder and restarted the player. when i connected the player again, my pc started to install a new usb-device rock27usb. at this moment when i trie to connect my mp4 player, nothing happens. no bootletter appears and i can't change anything hope someone can help me with my problem. what can i do??
thanks
Old 8th Sep 2008, 11:41 am
Have you got a copy of your firmware?
If yes then try to install it using this here:-
http://www.mympxplayer.org/rockchip-...v25-df881.html
Old 8th Sep 2008, 11:48 am
Default Re: rockchip rk2706 more than dead...
hey...thanks for your answer. i cant install anything, because i have no access to the mp4 player ....it is not listed anymore
Old 8th Sep 2008, 12:06 pm
Have you got a photo of your player?
Where did you buy it from?
Old 8th Sep 2008, 12:09 pm
at the point that windows tries to install a new usb device, if you point it to the correct drivers, not let windows do it, it should give you the hidden partition, this happened with mine, reformat it and then copy the files back
Old 8th Sep 2008, 9:52 pm
hey...
this is the player http://img0.chinavasion.com/images/c...118-6-rngl.JPG
when windows not install the drivers, there's also no boot letter who gives me access to the player folders (
Old 8th Sep 2008, 9:59 pm
hi
Originally Posted by beenchee";p=&quot View Post
hey...
if the player in the link is he one then this is NOT a 2706 player at all and there is no hidden partition
you are another victim of the onda vx858 clone player debacle
are you sure that is the correct player, does your player sort music by album, artist etc and do a "medialib" update after adding new music etc
what does the settings screen say about the player
looks to me like it is not an 2706 player at all and this is why rkusb tag wont work
Old 9th Sep 2008, 12:09 am
My Player not working. pls help me.
Old 9th Sep 2008, 12:11 am
iam trying Firmware Update. Finish the firmware update but not working my player.
Old 9th Sep 2008, 12:14 am
pls yr guide line send me my email: hiramusthafa@gmail.com
Strange Problem with my Rockchip RK2706... zirus Support and How To 0 6th Jun 2009 5:40 pm
rockchip rk2706 ... dead Lor3nzzo Dead Players 2 21st Apr 2009 11:55 am
rockchip rk2706 dead. plz hlp mohitanand Dead Players 7 24th Feb 2009 6:16 am
Rockchip RK2706 VX747 clone bug over Support and How To 3 26th Dec 2008 2:09 am
Rockchip RK2706 Datasheet David99 General Discussion 0 17th Aug 2008 1:07 pm
