MP4 PLayer ATJ2091N - MP9801 2 20070122 - need firmware
I've (stupidly) overwritten the firmware on my MP4 player and now all I've got is a white screen. Tried all the 9.xx series firmwares on the site and got some success updating with 9.0.48 and 9.0.50 but haven't managed to get one to actually work!
No brand name anywhere that I can see. It's a credit card size, 1.5 x 1.25 inch screen, 2GB, plays videos, has FM, built in speaker on right of screen above a silver control button, used to open with a starfield animation. The only details I can find on the player are posted in the title - the chip is a Samsung one (LAG08UOM if I recall correctly). I've tried the firmware sites and have had absolutely no luck finding those codes . Can anyone suggest where else I can try looking. This is the player: http://www.sinykon.com/products_info...d=1032&code=CG |
Re: MP4 PLayer ATJ2091N - MP9801 2 20070122 - need firmware
bro check this link and tell me your model no
http://www.sungworld.com/en/products_mp4-atj2091.asp then i will be givin' u the proper firmware... regards dapinder |
Thanks for the support but it doesn't look like any of those.
I've attached a link to my first mail of a Chinese site with a very similar looking player. |
i got the pic bro
lemme see for the firmware... i got all the details now and bro could you please help me with this http://www.mympxplayer.org/lookin-fi...2-vt11553.html this link regading my problem |
Unfortunately all the 2091N ones are dead links ......... |
| All times are GMT -7. The time now is 11:06 pm. |
