Looking for firmware LSD 501_02 sdk V35.37 2006_06_03
Old 28th Jan 2009, 11:55 am
You will have to keep looking. There should be some more numbers on there. You may have to open your player more.
Also, can you post some pictures of your player's board? If you can get a clear picture, that would be great.
Old 28th Jan 2009, 9:21 pm
TIP: sometimes the ID is hidden behind LCD flex cable (the orange one, soldered to PCB)
With a bunch of MP4 players for repair... and none will be mine , now that''s bad luck.
