Looking for firmware LSD 501_02 sdk V35.37 2006_06_03
Old 26th Nov 2008, 12:16 pm
Default Looking for lisong - LSD 501_02 SDK:V35.37
i update my firmware
lisong - LSD 501_02
SDK:V35.37
to
LSD 501_05
SDK: V35.37
but now player is dead, how can i remove the present firmware inseated of older one, please advice
Old 26th Nov 2008, 12:27 pm
First off, what kind of player do you have? There are many variations of the same firmware for different players. If you could post a pic or link to the player you bought, someone here might have the right firmware.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 1st Dec 2008, 11:57 am
Default Re: can anybody help me
Use dead player recovery procedure.
Open it up to find board and CPU ID, search firmware for those part numbers.
Old 7th Dec 2008, 2:24 am
how should i remove the present firmware? pls advice
Old 7th Dec 2008, 2:47 am
Unfortunately you can't "remove" the firmware, you will have to REPLACE it with one that is compatible with your player.
Do you have a copy of it on the CD that came with your player? Otherwise unfortunately you will have to search this site as well as search www.s1fw.com to try to find a compatible firmware for your player.
Good luck.
Old 7th Dec 2008, 5:22 am
http://s1fw.com/plus/search.php?keyw...e=titlekeyword
GOOD LUCK
Made in Shenzhen
Dead player
Old 18th Dec 2008, 11:14 am
the player is now behave like pen drive & showing two different drive... what should i do please advice
Old 18th Jan 2009, 10:15 am
Default firmware help
i update my mp3 player firmware
lisong LSD 501_02
sdk V35.37
2006_06_03
with a wrong firmware
you suggest me to send the board id & other id
there is two chip 1st one is
SAMSUNG 613
K9F2G08U0M
PI B0
USBA68BBC
and 2nd one is
ATJ2085W
F5120AB 55M
please suggest me the firmware
Old 19th Jan 2009, 11:41 am
You need to provide the BOARD number, not the one on the chips.
Search in the pcb, it is almost always a white text hidden somewhere in the board.
With a bunch of MP4 players for repair... and none will be mine , now that''s bad luck.
Old 28th Jan 2009, 10:57 am
sorry to say you there is no board id on it, in that case what sould i do??
