problem with onda VX858 clone
Old 6th Dec 2008, 1:45 am
Default problem with onda VX858 clone
Hi to all.
I've flashed a wrong firmware on my mp4.Fortunately I have found the correct fw and I've flash them, but now the screen is this way:
How do I do to make it return normal? :cry: :cry:
Matsca
Old 6th Dec 2008, 5:03 am
Default Re: problem with onda VX858 clone
hi Matsca
This firmware has been found to work for the inverted screen problem:-
http://www.s1fw.com/ROCK2608-Chip/HT...044-1-V01.html
good luck!
Old 6th Dec 2008, 10:43 am
I have downloaded it, but hen i insert it on ConsumerUpdate (3.1.0.0) it tell me:"Firmware file error". Can you upload the correct firmware, please?
regards
Matsca
Old 6th Dec 2008, 10:45 am
You need to delete the non-recognised chinese characters from the filename, then it will load in ok.
Old 14th Mar 2009, 1:31 pm
i have that problem.
i tried but its didnt work
i need htc-039c-rk-v2
2007-11-02
chen
original firmware
can anybody help me ?
VX858 Onda clone playlists? chinkostu Support and How To 0 19th Jul 2009 11:21 am
i may have original Firmware for my onda vx858 clone w/cam cyberdude974 Dead Players 1 29th Apr 2009 4:28 pm
Onda VX858 Clone Help!! Kazekage951 Mods and Themes 4 21st Mar 2009 8:23 am
PROBLEM dead mp4 player Onda VX858 2GB fortissimo91 Dead Players 0 6th Dec 2007 9:54 am
Onda VX858 LE problem whit RKL Logo Edit fortissimo91 Mods and Themes 3 30th Oct 2007 9:35 am
