My mp4 ipod (china) HELP...! plzzz
Old 12th Dec 2008, 10:06 pm
Default My mp4 ipod (china) HELP...! plzzz
how can i fix my ipod(china), ? any body help me, cuz, its stuck in hourglass..what should i do?
Tnx advance...
here is the pic.
Old 13th Dec 2008, 2:24 am
Default Re: My mp4 ipod (china) HELP...! plzzz
Please follow the DEAD PLAYER RECOVERY GUIDE from --> here.
Then you will have to find a suitable firmware for your player. Check your CD supplied with your player firstly, otherwise look at the board inside your player and post the Board ID and Plate ID here or search for it on www.s1fw.com or on my site to see if you can find one that's going to be compatible with your player.
Good luck.
OEM ipod( china mp4) question. help! kayz Support and How To 1 3rd Nov 2008 7:42 am
Hi,...ipod from china...(((white screen))) greekguy Support and How To 1 7th Jul 2008 1:14 am
Ipod from china can't connect to pc anymore bobby09120 Firmware 0 1st Jun 2008 1:39 am
fake 8GB ipod from china lior Support and How To 10 18th Jan 2007 2:07 pm
ipod nano fake from china Schiwi Bad sellers/Blacklist 0 19th Dec 2006 8:06 am
