3rd Gen Ipod Nano Clone Problem!
Old 23rd Dec 2008, 3:38 am
Default Re: 3rd Gen Ipod Nano Clone Problem!
http://www.s1fw.com/plus/search.php?...e=titlekeyword
There's an "LSD" one in that list, try it first.
Also try the others on there.
Old 18th Feb 2009, 8:18 pm
Originally Posted by XDude";p=&quot View Post
I tried to do the process in the sticky thread to recover the mp4 but i got stuck in the hardware upgrade thing! which one i have to choose?
I got s1mp3 ADFU driver and other is USB 2.0(HS) ADFU Device! I didnt got (FS) like it said on the tutorial! And secondly i have MP3 player product tool 5.12 and there it seems that i cannot do nothing as it cannot recognise the USB so pls help me as from all this you have understand that am a preety BIG noob!So pls tell me a good soft from which i can upgrad my firmware that is on the CD and also how to Fix this Mp4!
Hi, I have the same player...Did you ever get this to work? If so, where did you get the firmware? & what tool did you use?
Jason
Old 2nd Mar 2009, 11:08 pm
Nop it didn't worked atoll! Can anyone help me with the Firmware! It very rare and hard to find!
Old 6th Mar 2009, 11:54 am
Hello XDude.
I posted a posible solution here:
http://mympxplayer.org/firmware-ak10...1-vt12045.html
I think it is the same problem.
I hope it will help!!.
Old 10th Mar 2009, 11:05 pm
thnx alot! lemme check them! but the second one u posted on that post is not working! this one
Code:
http://www.s1fw.com/plus/download.php?open=0&aid=1344&cid=3
i mean i can download it its broken i think so can pls reupload it somewhere like rapidshare or megaupload so that i download it! thnx. will reply soon! hope it work
edited: i installed the first one but only thing am getting is a frozen sand clock so pls upload the second fw if u got it on ur HDD
  #16 (permalink)
Old 11th Mar 2009, 12:22 am
nop notworking m8! both of them gave life to my mp4 but the first one just stuck up on the hourglass and the second one is working perfectly but twisted and the menus were cycling automatically non stop and i cant do anything in there So what to do now? btw if ur mp4 worked can u get me an exact copy of ur player maybe that will work
  #17 (permalink)
Old 11th Mar 2009, 12:59 am
woot! It worked! :d abig thnx to u m8! thnx alot but its in chinese or probably japanese language and idk abit there written so where is the language changing button can pls help me
  #18 (permalink)
Old 11th Mar 2009, 1:36 am
Go into Setup and find the 语言 option. 英语 is English.
  #19 (permalink)
Old 11th Mar 2009, 2:51 am
thnx alot!
  #20 (permalink)
Old 11th Mar 2009, 4:18 am
i just found out that the Video is not working !! I dled a amv format video into the player but when i tried to play the video its not showing anything and i need to turn the player off and then on! what to do?
Problem with mp4 'ipod nano clone type' player jazf2008 Support and How To 0 10th Mar 2008 11:08 pm
Problem with my 1gb s1mp3 (mp4) like nano ipod Ramsus Firmware 0 10th Feb 2008 11:53 pm
I have a problem with my Fake nano Ipod Stone Fist Support and How To 4 5th Oct 2007 12:26 am
ipod nano clone 9.0.50 problem!!!!! kreuzberg Support and How To 8 14th Sep 2007 6:00 pm
Would a 3.7 V mAH Ipod Nano battery work in my nano clone? speedypear Support and How To 8 6th Mar 2007 8:32 pm
