-   -   HELP!!! i'm about to loose my mind (http://mympx.org/forum/dead-players/42785-help-im-about-loose-my-mind.html)
Apoc79 21st Dec 2008 2:47 pm
Re: HELP!!! i'm about to loose my mind
Yes copied my backup files accross but came up as white screen again...
Ok Here is what i managed to do so far:
used the chinese version of an firmware updater to create the 60GB partition (took another couple of hundred tries with shorting...BUT IT WORKS!) and let that copy the backup accross, kept showing up onscreen as ether red with "?????" in top right hand corner...
copied the tag file to the main and got access to the hidden, copied accross some other "firmware" and that got the "OS" back, quite a bit less nice then the one that was on here when i got it. That one had, when loading, a kind of a vista loading circle (with the dots) if you know what i mean, also all the icons was horisontal but this one has wording verticly.
Still doesnt take my backup though :( and the current problem is the player is really slow and about the only button that works is top one the right...
think this might take some time to get the right firmware though and then the matching "OS" firmware...
any advise on how to go about this would be great!
Knob, i realy want to thank you for all the assistance with this MASSIVE mission! Without it I would never have gotten it right! Thank you thank you! Thank you once more! :D
knob 21st Dec 2008 2:57 pm
You could try copying MY firmware over, my player does look like yours so it could be the same, your backup could be damaged:-
Mine is here:-
http://www.mympxplayer.org/rk27xx-fi...-8r-df890.html
Apoc79 21st Dec 2008 2:59 pm
one more quick by the by:
on the disk that came with this is a SPDA folder and in it a file called "Total MP SetupV4.07(1020).exe" you dont have a clean copy of this by any chance, this disk is totaly and utterly virus infected...
Apoc79 21st Dec 2008 3:03 pm
Jip that is the once I have tried but not working as should,
Very slow and some almost none of the buttons are working....
Do you think the button issue might be a firmware (chip) problem or a filesystem(4 folder OS) issue?
knob 21st Dec 2008 3:04 pm
Another firmware to try is this one:-
http://www.mympxplayer.org/rockchip-...219-df898.html
I threw away the disk from my player, it had all the wrong software tools on it, all the right tools you need you can get from this site in the
downloads.
If the buttons don't work it is the wrong firmware, I have had the same thing happen with my player you just need to try another firmware it's not a hardware problem.
Apoc79 21st Dec 2008 3:15 pm
downloads.
Alright, giving it a go now,,,
if you say firmware, is that rockchip firmware or is that the 4 folders you are talking about?
Apoc79 22nd Dec 2008 3:13 am
Hi again,
ok after a good nights sleep and a bit of tinkering i got that latest firmware onto the mp5,
looks exactly like mine but defaulted to spanish.
after a couple of tries, got it switched to english and look like this might be the one EXCEPT for the camara icon that is new and the error.
After about 7-10 seconds it comes up with an error:
LOW VOLTAGE
and cuts power to the device.
had it charged full on the wall adaptor but still comes up with the same error:)
SO CLOSE I CAN TAST VICTORY!!!!
Please can anyone assist with this problem?
I Have tried several different firmwares this is the only one that is close to what i had on to start with.
Is there any way of BLENDING my non functional, white sceen, firmware ORIGINAL BACKUP - with this one:
rockchip-firmware-rk2706-version-219-df898
Apoc79 22nd Dec 2008 5:37 pm
I Have tried just about every (OS) firmware out there and nothing!
think i need to try and reflash my chip again with different types of .RKW's
here is what I tried so far with the total collection of OS firmware (including my backup):
rk27sdk.rkw (this is where the whole problem began)
setup.rkw (Not working with and fw)
base.rkw (which came on my cd but no go for any of the FW or my backup)
Does anyone have something ells I Might try?
(Sleep, What sleep) YAWN....
Apoc79 23rd Dec 2008 2:31 am
hi all,
Think I got it down now!
I have messed up my player with the wrong firmware for my board using the supplied RK27DM utils RK27SDK.RFW file
To fix this I need a CR3005TFV3.3.RKW original file!
Please see below info:
Came accross this page:
http://www.mp4nation.net/forum/viewt...&sd=a&start=15
With this .RKW file:
http://www.yoto-cn.com/upload/2008051410285178332.rar
Which if extracted is this .RKW file version:
CR3003MNTQ06V2.0V2.3.RKW
THIS IS CLOSE TO WHAT I NEED!
some of my original backup FW is working like:
- Startup screen
- Battery charge
(but that is about all that is coming up...Main interface not working)
tried a couple of other FW, but none of those go, ether displaying red screen as before or white or GReen(which is new...HMM)
PLEASE! does any one have a link for this BOARD:
CR3005TFV3.3
I need a .RKW file like the on v2.0 one above but for the CR3005TFV3.3
Pritty sure this will get my chip up and running again so I can upload my backup.
Please have hunted all over the net and CN sites but unable to find the CR3005TFV3.3 MP5 player board mention!
Please if any has a player with a board like this and its .RKW file please let me know!
:) thanks
stedders 3rd Feb 2009 12:45 am
Originally Posted by Apoc79";p=&quot (Post 55282)
hi all,
http://www.mp4nation.net/forum/viewt...a&start=15
- Startup screen
- Battery charge
CR3005TFV3.3
:) thanks
If you are still struggling PM me as I have a different FW (hopefully)
for you.
