Can someone help me unbrick this?
Old 23rd Dec 2008, 3:34 pm
Default Can someone help me unbrick this?
Thanks in advance
Anyone know what firmware this player uses?
http://www.dealextreme.com/details.dx/sku.17286
Old 23rd Dec 2008, 6:22 pm
Default Re: Anyone know what fireware for this player?
Actions chipset, 9.x
That's as specific as I can get, if you want more detail you will need to provide board number and CPU.
Old 23rd Dec 2008, 6:55 pm
If you know how to get the thing out of its case I can do that. Unfortunately I took the bottom screws off and no dice. What firmware should I use if I want to get out of the hour glass of death?
Old 24th Dec 2008, 5:51 pm
Default Re: Can someone help me unbrick this?
The screen cover is glued to the inner frame. Pry it off and slide assembly out the top.
Example:
http://www.princeton.edu/~turesson/complete1.JPG
