Help needed for my dead player.
Old 26th Dec 2008, 10:46 am
Default Help needed for my dead player.
Hello ppl,
I have a Xintai mp4 player. Due to the fact that it didn't play fm radio as advertised I tried to flash it with another firmware. The player since then is dead.
I entered recovery mode doing the shortcircuit trick. I flashed it with a full firmware which made it able to work as a flash disk drive. After that I flashed it with another firmware in order to achieve full operation. By that time the player turns on and displays only a white screen. It does not do anything else.
The original firmware was named
XINTAI MP3 player
Wilson Co. Ltd.
9.1.52
And these are infos from chipgenius
Device Name: +[H:]+USB Mass Storage Device(USB 2.0 (HS) Flash Disk USB Device)
PnP Device ID: VID = 10D6 PID = 1101
Serial Number: A00000600001
Revision: 1.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: Actions
Chip Part-Number: ATJ209X/ACU75XX/ATJ2063
Product Vendor: (N/A)
Product Model: MP3 Player
Here are two photos. The exterior and interior of the player.
Click the image to open in full size.Click the image to open in full size.
The left chip says
hynix kor
HY27UT088G2M
TPCB 803A
MTUJ8777Q
The right one says
AK1025
7K057AB 0KM
So, I am looking for a matching firmware in order to revive my player.
Old 26th Dec 2008, 6:21 pm
Default Re: Help needed for my dead player.
The picture is too blurry to see board ID or anything else but your player does not have FM radio, if it did the FM module would be soldered on the square white area next to the flash.
We will need the board ID to find a suitable firmware. Look for it, it may be on the other side as well.
Old 27th Dec 2008, 3:37 am
I opened it and as you already said there is something written in the back side. It says
0748
K915H2U2M
0UT 070326
There is also a second board connected to the mainboard in which there are the buttons and the usb connector. This board says
0748
K915U2K1
0UT070326
That's all. Nothing more written in the pcb.
Old 27th Dec 2008, 7:21 am
I have firmware Mustek 1803, uploading from work on Monday.
http://www.compkaz.ru/www/pics/test/test_060308_2.jpg
Old 28th Dec 2008, 11:31 am
This firmware. http://rapidshare.com/files/177623563/MP1803.rar.html
Old 29th Dec 2008, 4:28 am
It does not work.
Thank you anyway Alexandr!
Help Needed for Dead player (PM-711C-CL-V4.0). iimraann Dead Players 10 27th Dec 2008 6:08 pm
stuck in the middle of dead player restoration help needed! dragonfly Dead Players 3 11th Dec 2008 10:35 am
Dead mp4 player.Original Firmware needed!! Board:K9129H2V2M prymor Dead Players 0 6th Nov 2008 11:27 am
MP-693C-SL firmware needed for dead player recovery. Daniele80 Dead Players 4 21st May 2008 2:19 am
Dead digital mp4 player help needed ergently! Louis Dead Players 2 26th Apr 2006 3:06 pm
