Need some firmware
Old 26th Dec 2008, 8:03 pm
Default Need some firmware
It looks exactly like this player:
Stuck on the hourglass.
Opened it up cant see any numbers on the chips.
One of the chips it runs to the edge of the mainboard and looks like it has 2 or 3 pins put together on each side of the chip, I dont know if they are soldered together or if it was designed that way.
Old 26th Dec 2008, 9:17 pm
Default Re: Need some firmware
You will need to open your player and find the board and plate ID number for your player to be able to find a suitable firmware that is most likely to be compatible with your player.
Take a look at this post here: S1 MP3 PLAYER firmware download site - s1fw.com.
Please post your findings here in this post again.
