I need revive MP4 NEX MPX-242
  #21 (permalink)
Old 30th Dec 2008, 12:27 pm
i can Upload the firmware !.. so..
in the screen appear signs :S and the screen withe :S !!... what i can do? XD lol
  #22 (permalink)
Old 30th Dec 2008, 1:53 pm
Default MP4 NEX MPX-242 :S
hi i need firmware of this mp4
i dont cant find another specification of the mp4 more with this" "JS835(2506)V1.0 20070827 "
i try with this firmware
http://www.s1fw.com/plus/download.ph...id=78634&cid=3
and nothing happend... the screen is in withe
ok bye thakns to all !
  #23 (permalink)
Old 1st Jan 2009, 2:54 pm
Here have more details
* Procesador RockChip RK2606A
* Board JS835(2606)V1.0 20070827
* Memory SAMSUNG 813 K9LAG08U0A
* Display
* Bios T&T TO51V161601A-6T
* CHIP RADIO TEA5667
* Bateria 3.7v 500mAh Model 033447
* Amplificador LM 4890
* Chip ZL54 Charger
* Chip A18m
* Screen of 24.000
:/ i don't can find the correct firmware !!
::S:S:S:S
PD : HAPPY NEW YEAR TO ALL !!!
  #24 (permalink)
Old 4th Jan 2009, 1:29 pm
wow i can revive my mp4
thanks XD
lol
is the chinese characterers the problem
lol
xD
ty
all
bye!!
  #25 (permalink)
Old 12th Jan 2009, 1:13 am
edit:
don't mind me, i've posted some help-text without realizing there was a 2nd page lol
can you tell me a thing? when the update program says "Manufacturer of NAND flash not supported"... ¿how you corrected that error? i have a similar player with the right firmware, but cannot upload it because of that...
sorry, postee sin ver que habia una 2da pagina xD, era para ayudar nomas de todas formas lol
puedo hacerte una pregunta? cuando te salia ese error "Manufacturer of NAND flash not supported"... ¿como arreglaste eso y pasaste esa parte? tengo un MP4 similar y hasta el firmware correcto, pero no me deja actualizar por ese error que sale...
  #26 (permalink)
Old 13th Jan 2009, 10:32 am
Default Re: I need revive MP4 NEX MPX-242
JAOjAO alghien q habla español mira si te tira ese error es por q estas haciendo el puente con los cables sierto?!, bueno cuando hagas el puente y conectes el USB al computador una vez q suene la alerta q se conecto el USB saka el puente osea el cable y subele el firmware eso es el problema q por lo menos yo siempre tube conectado el puente por eso me tiraba ese error ....
espero que me entiendas..
Conecta el USB
Suena la alerta del PC y sakas el cable del puente en el chip
y ahora subes el firmware y listo
Olle si puedes me mandas el Firmware a mi correo o lo subes xfa el firmware q tengo bale kallampa
AOjao
The problem is the birdge in the chip
You connect the USB to the PC
the PC know the mp4 and you emm put out the bridge
and of this form know the program the Mp4
chauu
  #27 (permalink)
Old 13th Jan 2009, 5:56 pm
El fw que tengo no tiene nada que ver con el tuyo xD, si se lo metes a tu mp4 lo mas seguro es que lo matas. Lo que pasa es que el mio usa el mismo chip RK2606A, misma pantalla... pero diferente placa, hasta ahi nomas llega el parecido
Ademas que ni le hago el puente, apenas lo enchufo lo toma altiro en modo rockusb :S
Yo cacho que quizas el chip flash murio o algo asi, espero que no... Gracias igual wn ;D xd
The thing is... i don't even need to make the bridge on the flash IC, the player enter rockusb mode immediately after connected to USB. And the program seems to not recognize the flash IC... it's like it just died :S, hope it doesn't... thanks anyway.
With a bunch of MP4 players for repair... and none will be mine , now that''s bad luck.
  #28 (permalink)
Old 14th Jan 2009, 6:36 am
olle entonces hace el puente !!...
eso solusiona ese problema...
intentalo no pierdes nada...
y es refacil JOAAJoajoaoaJoa...
olle pero el firmware q tienes, q menu es? es el mismo q lanza el mio?XD :S
ya si puedes subelo = si el mio tiene otro firmware pero se ve como las weas ese es el problema... kisas la screen la q ta weiando.. emmm
ya eso pruieba con el puente pos...xauu!
Hey so try with the bridge
this solutiont this problem....
try dont lose nothing lolxD
and is very easy
hey, but the firmware when you have, what menu is? its same launch my?xD :S
upload the archive plz XD
lol
( sorry for my bad english !! )
  #29 (permalink)
Old 15th Jan 2009, 2:13 pm
Es que no tengo p*ta idea de como es el menu... esta cosa llego muerta a mis manos :S
Al final lo intenté de una y mil maneras pero nada, estoy que lo mando a la chucha wakjajkakja
¿Como es eso de que se ve mal la pantala? prueba ajustando el contraste y weas...
No idea how the menu looks on my player, it came already dead to me :S
I'm getting sick with it, tried by many ways and still nothing hahaha
If the screen in your player looks bad, try adjusting bright/contrast and stuff like that...
  #30 (permalink)
Old 16th Jan 2009, 3:33 pm
mmm weno
el menu es mm es el q sale aki
http://mympxplayer.org/pafiledb/imag...shots/C204.jpg
el mp4 al parecer es uno de esos parecido..
AJoaJoajel mio.. el firmware es super xarxa... el q tengo yo ahora pero igual sirve la wea..
olle me podi dar tu msn para hablar mejor 1313 JOAjOAjoa XDD...
ya el mio es luishop_@hotmail.com
hay para no andar weiando por ak por q las respuestas son mxo mas lentas
pero x msn te ayudo es refacil...
nos behemoth!
need help revive my MP5 MP4 MP3 player Grotz Support and How To 2 3rd Dec 2008 8:05 am
sony fake mp4 dead... no power..how to revive AT2085H quedee99 Dead Players 0 26th Jul 2008 7:28 pm
cant revive my mp4 nicean10 Dead Players 0 2nd Aug 2006 12:44 am
My player is half dead how do i revive it ghov Dead Players 7 1st Aug 2006 4:38 pm
How to "REVIVE" your dead player for MP4 g3rmansh3ph3rd Dead Players 1 16th Apr 2006 1:47 am
