Upgrade problem
Old 5th Jan 2009, 10:30 am
Default Upgrade problem
Hi,
I've updated the firmware of my player (original firmware: LS 101 V10) to version LS 101 V12 but it's not working properly. First, everything works correctly (buttons, menu, screen and functions) but after some reboots the player gets stuck on "start" mode and keeps on rebooting automatically. :shock:
Even if I try to re-install the same firmware it does like that, but before the upgrade the player was perfectly working.
I DON'T HAVE THE ORIGINAL FIRMWARE but I have already tried EVERY similar firmware. The ones that are supported and compatible are:
http://www.s1fw.com/Firmware-1/rui-f...070303-fw.html
and
http://www.s1fw.com/Actions-AK102X/A...50-070303.html
(WHICH ARE IN FACT LS 101 V12!!!)
What's the problem with it? Could it be that the chip has been damaged because of so many flashes (operations)?
Sometimes, after an upgrade of the same firmware, the player keeps the settings of the previous firmware... Is it normal? :shock:
Can the memory have something to do with it?
chip: ATJ2091N
memory: SAMSUNG 707 K9----------8UOM
plate: K916H2V1M 0UT070116 0704
screen: TFT60005ACT6-BLA 07/2/15
original firmware:LS101V10 ACT V_9.0.50 03/03/07
Thanks a lot!
Old 7th Jan 2009, 9:27 pm
Default Re: Upgrade problem
Why are you hiding your flash chip's part#? If you're trying to hide the fact that it only has an endurance of 1500 erase/program cycles, that won't work.
Old 11th Jan 2009, 2:49 pm
The number of the memory is erased because of the sticker.
I made maximum 200 tries of upgrading.
Can someone solve my problem?
Old 12th Jan 2009, 12:44 am
It's a kinda basic thing, but ...
¿have you tried formatting the player in FAT16 after you upgraded FW, or used the player as-is?
Also if it's something with the flash chip, you could try using Action's Production Tools (i recommend 4.19) to completely erase the flash chip & uploading the fw again, sometimes thath helps with ill-behaved players.
Tip: if the update process ends almost immediately but say Sucessful anyway, it's most likely that the program DOESN'T upgraded or written anything on the player. That could explain your "after an upgrade of the same firmware, the player keeps the settings of the previous firmware" problem...
Old 12th Jan 2009, 3:17 pm
Hi!
I'd like to erase the ATJ chip but with Tools 4.19 the "erase flash" button remains unclickable even if the device is found. The other functions are working!
What's wrong?
Thanks!!!
sunplus SPMP3052A upgrade problem rulerofwar Support and How To 3 27th Jan 2009 10:44 pm
problem with "upgrade tool" r.invaders Dead Players 2 23rd Dec 2008 12:11 pm
please help me fw upgrade vvizard Support and How To 3 18th Oct 2006 12:49 pm
to upgrade or not to upgrade sneekie General Discussion 5 6th Aug 2006 9:13 am
How do you upgrade vstro24 Support and How To 6 11th Jun 2006 7:13 pm
