Dead Player searching for the right firmware
Old 18th Jan 2009, 4:05 am
Default Dead Player searching for the right firmware
Hello everybody,
I found this MP4 a few days ago but as you can see on the following pictures, the screen seems to have a problem. I tried to update it to solve the problem (I had to use the hardware way to activate the RockUSB Device, but now it works) but I think I haven't found the right firmware for this device.
The chip is a Rockchip RK2608A, If somebody have the firmware for this device, i would be nice.
The device opened...
The Front of the device
The screen !!!
Thanks a lot
QuiGonJinn37
Old 18th Jan 2009, 6:43 am
Default Re: Dead Player searching for the right firmware
To help you look for some FW you need the serial of board and screen (maybe in the other side?)
Old 18th Jan 2009, 7:14 am
Hello again, here is what I found:
On the board (behind the screen): HTC-039C-RK-V2 2007-11-02 CHEN
Is that what you needed ?
Old 18th Jan 2009, 7:15 am
There is alco that, that is written on the cable between the board and the screen: CFO28LCD20-37A VO
Old 19th Jan 2009, 11:46 am
Try with this one: http://www.s1fw.com/plus/download.ph...&aid=861&cid=3
But first, BACKUP your current firmware in case something goes wrong
(it's better to have your player like this, than a plain dead one)
With a bunch of MP4 players for repair... and none will be mine , now that''s bad luck.
Old 20th Jan 2009, 2:53 am
Thank you, I will try this one, but actually I can't use my player with the screen in this state so there is nothing to loose
Old 20th Jan 2009, 3:47 am
Well, I flashed the player successfully, but it is still stuck on this screen... I begin to think that the problem is more a hardware one than a firmware one...
Old 20th Jan 2009, 6:57 pm
Look at the LCD flex-cable soldering to the PCB, sometimes it isn't soldered well. Also there are often tiny solder balls in between solder pads, that make short-circuit and cause the display to malfunction. But these are rare things anyway...
Also look at the LCD ID and post it here, it's written in the flex cable.
Maybe the firmware I gave you isn't compatible at all.
Old 24th Jan 2009, 1:18 am
The LCD ID written on the flex cable is: CFO28LCD20-37A VO
I will check the soldering of the LCD, but I don't think it is the problem....
Thanks anyway
searching a firmware and a help for mod my mp4 player -Blade- Support and How To 5 8th Jul 2008 4:08 am
Searching for a MP4 player victoriasmith General Discussion 1 9th Apr 2008 5:47 am
Searching For Drivers for my MP3 Player...? bigbear1460 Support and How To 0 5th Apr 2008 2:27 pm
Searching correct Firmware... doener_mann Dead Players 4 2nd Dec 2007 5:43 am
Searching for firmware to mp3 corifey Dead Players 0 14th Feb 2007 1:57 am
