1st Feb 2009, 9:30 pm
Re: Pls provide solution to my problem
CM50011 = 128x128 1.48"
CM50012 = 128x160 1.8"
Where is this "LG_LWL_KJT-781FV2_CM50011_AK1025 _V9.1.52" you speak of? Post a link to it, I can't find KJT-781FV2 with CM50011.
What do you mean by "then there will be the display and if i press any key the screen went blank for few seconds and displays" ? Is the display completely correct, but the keys are nonfunctional?
Either way, you may need a display driver or key driver swap.
