problem with ADFU & wrong firmware
Old 13th Feb 2009, 6:42 am
Default problem with ADFU & wrong firmware
Hi
I've Mp4 2G GIGAMAX just like this one
http://www.chinavasion.com/product_i...sword-setting/
suddenly it stop playing and I thought about updating it or at least restore its original firmware (as written in firmware version)
2006-11-02
9.1.50
2006-12-05
ctw500n_v50
anyway, I try so many firmwares untill I upload one that make the player refuse to recover Firmware
I think about format it but it didn't resolve the problem
windows format gives error message that it can't format
and the device is not visible on DOS
but when I change from FAT32 to FAT it format and DOS can access it
I found some folders and files with unbelievable sizes, the sum = 12G !!!!!!
I try to delete but the system didn't recognize there
even the dos
I ask for help to do the following:
- remove this firmware
- find the right one for this device
Old 14th Feb 2009, 12:09 am
Default Re: how to completely remove the firmware
Use DEAD PLAYER RECOVERY GUIDE to force it into ADFU.
Then upload the firmware. It will overwrite existing firmware.
Old 14th Feb 2009, 6:04 am
Thanks lolita
I've tried this before and it works untill I try to install firmware that is making the device accessible but of no use
I can see it in explorer but the upgrade tool crashes in the middle of the operation
actually it happen like this:
I select the new firmware and start to upload it to the device
the firmware begin to upload and in the state bar it writes (display the connection picture) and the screen goes on & off one time
then the update tool gives message that the device is not accessible and ask to review the connection
at this point the device is connected but the windows nor the dos can feel it
I've to unplug it and connect it again
then it appear as a removable disk
I try to upgrade the firmware many times and this is happening everytime
Old 15th Feb 2009, 1:35 pm
I found something that may work here
http://www.ycibo.com/mp4help/index.htm
I discovered that my device is recognized as flas usb
the question is
How I turn it from flash usb to ADFU?
Old 15th Feb 2009, 10:29 pm
Use dead player recovery guide.
Old 16th Feb 2009, 8:13 am
I did!
but once I plug it to the computer, Windows install it as USB flash memoery driver not ADFU
I remove the driver and repeat but same result
Old 16th Feb 2009, 2:30 pm
I found some topics about the problem, I try everything written there... still recognized as usb not ADFU
http://mympxplayer.org/pc-cant-insta...p4-vt8118.html
Old 16th Feb 2009, 3:15 pm
when I try to change firmware it gives me that message
Old 16th Feb 2009, 11:48 pm
Default sage
Did you even read the dead player recovery guide? Sometimes it takes a few tries to get the data pins shorted properly and then it'll go ADFU.
Old 20th Feb 2009, 4:32 am
thanks lolita
yes I read it and do it many times, and I've discovered many of people had this problem just like me
[U][b]Pls help! Wrong Firmware problem. MP4 player 2GB with deeplyours Support and How To 0 5th Apr 2008 6:18 am
Problem With ADFU driver plz help mladen133 Dead Players 3 5th Feb 2008 6:36 am
Problem With ADFU driver plz help mladen133 Dead Players 0 1st Feb 2008 2:22 am
[solved] serious problem with adfu lostone Dead Players 11 31st Oct 2007 6:43 pm
Looking for 9.0.48 wrong firmware yusufyumer Dead Players 1 31st Mar 2007 7:04 pm
