Help with my dead player
Old 16th Feb 2009, 6:32 am
Default Help with my dead player
hello!
by mistake I upgraded the firmware of my mp4 and now it no longer works .. the screen is shining but does not appear the menu .. :cry:
model: http://mympxplayer.org/album_pic.php?pic_id=631
the problem is I dont have the original firmware (my mp4 does not come with CD) .. and I not found to download ..
the version of firmware is: xid 9112 10
Anybody know where can I find?
and i dont now where i find board id.. help? :roll:
thx!
Old 16th Feb 2009, 11:43 pm
Default Re: Help with my dead player
Open it up and look for the board ID and CPU... also getting the part number of the display would be a good idea.
If we can't find an exact match your player is 'Glacier' type, there are many firmware collection for it.
Old 17th Feb 2009, 10:10 am
hi..
i found board id and screen.. but not cpu.. =\
id board: QY-037FV0-M 2007.02.09
screen: xyxw029 081120-d
firmware: xid 9112 10 9.1.52
i found this firmware
http://s1fw.com/plus/search.php?keyw...e=titlekeyword
but i try every 5 and not work..
i try restore firmware with mp3 player utilities 4.05, 4.18 and 4.19..
Old 17th Feb 2009, 11:30 pm
CPU part# is written on the small square IC, but not the one with 3767 on it.
You can search Internet for more QY-037 firmware to try.
Old 18th Feb 2009, 9:50 am
i found 2 small square IC..
1º : AK1025 8H036AB 1I2
2º : TEA5767 VDJ2K0 02 DuG6483Y
in butons board i found: QY-037FVO-K 2007.02.09
Old 20th Feb 2009, 11:31 am
i have some news... not as good as i like.. but good..
1 question before.. when i update for first time firmware on recover folder i found one firmware ($ACTSDK$.FW)..
this firmware is a backup of my mp4 before i update or this is a program file?
look..
i try some firmware and none had to do anything in mp4..
when i update with $ACTSDK$.FW the button play/pause/on/off function works normally.. i turn on player (screen only light but i cant see anything) and press >> and i found radio and can hear normally...
someone knows something what may happening with my player? or know how to teach me to fix it ? or the only way to fix it is testing another firmwares?
thx!
Old 20th Feb 2009, 8:01 pm
You'll need to figure out what display driver you have
Old 22nd Feb 2009, 6:51 am
Display Drive is LCD right?
i hav 2 numbers..
below: FGD177SLW-33B9-1
F177091S
3G-7626
right side: xyxw029 081120-d
i need find firmware with LCD number now?
Old 22nd Feb 2009, 6:42 pm
Try these FGD177FLW firmware:
http://www.s1fw.com/plus/search.php?...e=titlekeyword
Old 26th Feb 2009, 5:02 pm
i try all.. but anyone work..
the first work as a describe above (with $ACTSDK$.FW) screen not work too..
with others nothing works...
MP4 DEAD THIS IS THE CPU AND BOARD POST, DEAD PLAYER manikakoto Dead Players 0 9th Feb 2009 3:08 pm
Dead Player i think very dead... DzoniHSV Dead Players 13 10th Aug 2007 12:13 am
dead player, so very very dead Kosh Dead Players 4 1st May 2007 6:48 am
Dead well almost dead MP4 Digital Player Zest Dead Players 6 28th Jul 2006 9:59 pm
