Another MP3 player stuck on hourglass..
Old 18th Feb 2009, 12:53 pm
Default Another MP3 player stuck on hourglass..
Ok, I already fixed an hourglass issue on about 8 players earlier this week. It was a Golzi G-18A 9.1.52 & they work better then ever now..
I had another player that looked a lot like the Golzi ones &decided to download the Golzi firmware because it looked better...BIG MISTAKE!
When I finished the firmware upgrade the MP3 screen flashed & just turned white... As luck would have it I had another player here exact same model , so I used the s1fwx tool to extract the firmware from the working MP3.. It extracted a dump bin.. so I opened the upgrade tool & upgraded the firmware with the dump.bin.. After doing this, my MP3 player came back on, but stuck on hourglass...
I'm not sure why?? If the dump.bin from the working player included the firmware or an exact copy of the flash, shouldn't the other player work??
Did I miss a step? Is there something else I need to do?
Ftanl
Old 18th Feb 2009, 1:02 pm
Just so you know this is a 3rd generation ipod look a like.
(Firmware version)
MP3 Player
LSD_91n18H_A2
2008-04-05
9.1.52
I believe its a Lysong or something..
On the screen it says.
JE-C230-180-01 08.10.06
1 Chip says AK1025 ( 8H013AB 1H7)
under that chip on the board it says
K9129H2V2M
Another Chip says:
Hynix kor
HY27UU08AG5A
on the main board..not sure what it is?
Flash(Slaver)
any help would be greatly appreciated.
Ftanl
Old 18th Feb 2009, 8:30 pm
is there an s1clone tool that compatible with 9.1.5x players??
I have 1 player that's messed up..
Another one that's exactly the same..works perfect!
So how or what can I use to clone the good one to the bad one??
ftanl
Old 18th Feb 2009, 10:15 pm
Ok guys I got the clone file flashed..
when I plug in the bad Mp3 and click on write to flash it goes for about 5 mins & then it shuts my computer down..any ideas???
It told me in the error report that an unknown USB device...( My Mp3) was detected..Windows shut down to protect my PC..
Has this happened to anyone else?? I know I'm close to fixing this, but I'm unclear of all the steps..
Please help me with s1clone
Old 18th Feb 2009, 11:46 pm
Default Re: Another MP3 player stuck on hourglass..
Look around on the board for the ID. You might have to flip it over, check everywhere.
Post pictures and we can help.
But getting an hourglass is good already, it means you have a firmware with compatible screen driver. (Otherwise it couldn't even show the hourglass.)
Old 19th Feb 2009, 2:04 am
s1fwx *doesn't* do a FULL firmware extraction. You still need a full firmware which is compatible with your player to relive your player completely.
So as you flashed it with an incompatible firmware then tried to use the dumped firmware (not full firmware), it shows up with the hourglass as the dumped firmware isn't a full extraction of the firmware on your player. It's only partial unfortunately.
Old 19th Feb 2009, 3:21 pm
Thanks for the reply..
Is there a tool I can use to extract the Full firmware from a working player??
I can't find a suitable firmware for the below player anywhere..If I could extract a full version from a working player..that ould solve my problem.
Firmware version)
MP3 Player
LSD_91n18H_A2
2008-04-05
9.1.52
Ftanl
Old 9th Mar 2009, 7:02 am
Hello ftanl
Yes there is, you can do it with s1clone v2.0. You can download it from here:
http://www.s1mp3.de/tools.s1clone.html
Support for a wider range of v9 devices.
I have the same player as you. If you achieve to create the firmware backup I would like you to send me the backup. Because my player is death now and I can't find the firmware.
Thanks and I hope it will help!!
Hourglass stuck on ipod vhone601 Dead Players 19 17th Jul 2010 6:58 am
help me (hourglass) stuck problem dashingd Dead Players 0 1st Oct 2007 2:23 am
8gb Stuck on the Hourglass, HELP!!!!!! W0mble Dead Players 0 31st Jul 2007 9:39 pm
player stuck on hourglass labroi2007 Dead Players 0 29th Jul 2007 8:25 pm
Stuck on hourglass imok Dead Players 3 2nd May 2007 5:21 am
