Mp4 Charging problem
Old 21st Feb 2009, 12:14 am
Default Mp4 Charging problem
Hello.. Guys help me.. Everytime i charge my mp4 for long hours still not power on.. but it works when i leave the charger plugged.. its a sony made in japan .. sorry for my english. thanks!
Old 21st Feb 2009, 2:41 am
Try using a DIFFERENT USB cable instead and see if that helps.
Have you also tried charging it from both the computer and the wall?
If those all fail, and it seems to be a problem with the battery or the connection on the battery that the charge is not getting into the battery. It's powering the power when plugged in but the connection on the battery is either faulty of loose so not getting charged up.
charging with pc problem darkzer0 Support and How To 1 17th Jul 2008 1:39 pm
Video watch usb charging/starting problem madgamepro Support and How To 0 1st Apr 2008 12:35 pm
Charging problem spyrex Support and How To 1 26th Apr 2007 9:36 am
Charging Problem port3460 Support and How To 8 3rd Apr 2007 8:33 am
Charging problem with MP4 player Brett92 Support and How To 22 24th Mar 2007 1:37 am
