Need some help or advice
Old 24th Feb 2009, 4:35 am
Default Need some help or advice
Hi guys
I have a persistant error with "Flash not responding error"
I have been trying to use Firmware 9.0.50 and the player is a
1GB MP4 digital like the one in the photo:
I have been using both normal mp3 tools 3.58 etc and update tool 5.11
they all come up with the same error (ADFU is recognised) then during upload of firmware I keep getting "Flash not responding " does that mean the player is completely dead now ??
do you know if I this means I use the wrong FW..
does anyone know which one is the most correct ?
Any advice or suggestion ??Click the image to open in full size.
Old 26th Feb 2009, 12:34 am
Default Re: Need some help or advice
Post board ID and CPU.
Advice for a new battery xjay Support and How To 1 18th Apr 2009 9:00 pm
I need your advice man88e Bad sellers/Blacklist 13 9th Aug 2007 6:16 am
Need some advice for my next player. kope007 General Discussion 15 25th Jul 2007 3:23 am
Need help / advice with iClone javo Support and How To 5 13th Apr 2007 9:11 am
I need advice please help mm111 General Discussion 1 22nd Nov 2006 3:44 am
