problem with flashing
Old 4th Mar 2009, 7:34 am
Default problem with flashing
this happens when i tray to inter any afirmware to my mp4
the mp4 is showing the timer sandwatch and do nothing
the info is
Plate Number :- XT9131_V2 20080223YE
Screen Number:- c14401B-v1
LKD1697v
c144-01-v3
AK1025 THE MAIN SMALL CHIP
if any one have the firmarw please post iy here
thanks in advanced
Old 4th Mar 2009, 7:19 pm
Default Re: problem with flashing
Get it into 'hard' ADFU mode first, using DEAD PLAYER RECOVERY GUIDE. Unless your boot ROM or other hardware is damaged, hard ADFU will always work.
Old 7th Mar 2009, 3:38 am
ok lolita many thanks
i have solved this problem and i will tell you how it did work for me to help others ..
i used my tweezers to short circuit the mp4 is off than i turned it on it did Not light up its okay just give it the firmwar like that it will accept it .
put now i am stuck with the right firmware cant find the right one any help please ..
thanks
Old 8th Mar 2009, 12:41 am
Try these
http://www.s1fw.com/plus/search.php?...e=titlekeyword
Old 8th Mar 2009, 4:30 pm
now it gives me this
words cant help me to say thanks
Old 8th Mar 2009, 11:17 pm
Which one did you try? What player utility version are you using?
Some version cannot handle new encrypted format.
Old 10th Mar 2009, 2:16 pm
i have downloaded them all Lolita and try them one by one ..one firmware completed and now the mp4 light the screen without any thing on it ..
ans yes i use MP3 Player Utilities5.09
many thanks
Old 10th Mar 2009, 9:47 pm
Try the player utility v10.00.
Old 11th Mar 2009, 1:00 pm
i cant find it could you please give me some link
Old 12th Mar 2009, 1:28 am
http://rapidshare.com/files/20825581...0_20070822.rar
Flashing Help rukmal Dead Players 0 14th Aug 2009 1:29 am
dead uxcell.com 4gb glacier with flashing white screen justwanttunes Dead Players 0 26th Jul 2008 3:38 pm
Wrong flashing ONDA VX858LE heat666 Dead Players 12 24th Nov 2007 8:31 pm
big mistake flashing onda 858le any possible help paul01609 Dead Players 42 20th Oct 2007 8:39 pm
Problem after Flashing my Player DJ-Neo Support and How To 1 28th Dec 2006 7:46 pm
