Dead player, need help!
Hi,
I have this player. It worked well for few days, then I had to recharge the battery. I did this via USB. After recharging I tried to power on the player, but it just flashed the screen red and won't power on anymore. PC recognizes it as USB Device, so I think there's still hope to recover this piece of "you-know-what". I tried to follow the guide about dead players, but stucked at AdufUpdate.inf. I downloaded the files and placed .sys file in windows/system32/drivers and the .inf file to /windows/inf and still it gives me the error Quote:
Re: Dead player, need help!
You have a Rockchip-based player, open it up and find the exact part numbers.
Nevermind anymore.. I tried to fix it with another guide in school and managed to break it completely.
First, I accidentally dropped it to floor causing component detach. Then I soldered it back, after that PC couldn't recognize it anymore, even as USB device. Then I stabbed screwdriver through it, didn't work also.. I wonder why |
| All times are GMT -7. The time now is 12:46 pm. |
