My Player is white only - need help
Old 3rd May 2009, 6:44 am
Default My Player is white only - need help
Hello,
i want to use an older firmware with my player, cause the battery was empty after 2 hours music. On this page, i've found another firmwares. I' choosen any and it send to the player. After restart he only shows "white" on the display. I can see the player with the explorer and can format it with windows too. But i can't use him, cause i see nothing. Mp3 Player upgrade tool schows the original firmware:
Devive Name: LISONG MP3 Player
Producter: Wilson Co. Ltd.
Version: 9.0.48
Here i have made a picture from the player. I is very bad quality but i hope it is okay. I need help.
Sorry for my bad english. I hope you understand it.
Old 3rd May 2009, 9:04 pm
Default Re: My Player is white only - need help
Open it up, post board, display and CPU ID...
Old 4th May 2009, 10:43 am
Ok,
there are two ICs.
the bigger one:
SAMSUNG 649
K9LAGO8UOM
and on the other:
ATJ2093H
F8199FA 59E
Another Question. Can i use a Accu with more than 280 mAh ?? If yes, where can i buy someone.
Hope you can helf me.
Old 4th May 2009, 11:33 pm
Now find the board and display ID.
Old 5th May 2009, 10:08 am
Well on the board:
LS305AV2
2006.11.10
and on the display:
BKL-LWI 027A SG1 42024-3
Thanks for Help
Old 5th May 2009, 8:30 pm
http://www.s1fw.com/plus/search.php?...e=titlekeyword
Those are are all AV1 version but give it a try.
Old 6th May 2009, 5:05 am
How can i download the firmwares? The are no "download" buttons or something like this. If i click on the wort behind download the is comes an error. Hope you can help me.
Old 7th May 2009, 12:04 am
s1fw.com has been broken lately... I've already sent a message to the owner to tell him about it but he hasn't replied.
You can either try the ATJ2093 firmware that you _can_ download from there until it works, or if you have basic understanding of electronics, trace the PCB to find the connectivity of the display and keyboard, then try narrowing down your search based on that criteria.
Old 7th May 2009, 6:30 am
the page doesn't work. Are there no other servers where i can download the fimrware? Why i can't use some firmware from this forum server? I don't have basic understnading of electronics. Does the Mp3 Player Upgrade tool make a backup bevor it sends the new firmware to the player?
Hope you can help me und hope that de server goes on.
White Screen Ipod 3rd Gen MP4 Player young_sien Dead Players 6 22nd May 2009 11:23 pm
Dead player with white screen chrissy123 Dead Players 2 27th Nov 2007 2:48 pm
Player is working OK, but I have WHITE screen Den Dead Players 2 28th Apr 2007 10:58 pm
Glacier - Screen white then flickers then white again clackers91 General Discussion - Uxcell.com 6 2nd Mar 2007 3:21 pm
MP4 1GB/4GB player with white boot screen help NovaFoil Dead Players 4 10th Feb 2007 7:53 am
