Recovering firmware
Old 24th May 2009, 4:43 am
Default Recovering firmware
Hi.
I bought from ebay a mp3 player with OLED display and it's suppoused to have 8GB memory. Actually, there was some problems with fulling this capacity - when I sent there 10 folders with different intepretes, folder names copied right, but the content of folders was same.
So I tried to format whole memory, but after that, it stucks on "Starting..." screen with hourglass.
I spent few hours with reading your forum, Recovery guide and others - actually I get player connected in Vista as "Actions USB 2.0 (HS) WinUSB Device", but I can't find (better say can't download) the right FW which I could try through MP3 Player Update Tool. I found some firmware on S1FW.com site, but im completely unable to download them.
Chip is ATJ2091
Memory is Samsung 904 K9GAG08U0M PCB0
Plate is MP3-910002 Ver. 3.0
(info about player from ebay where i bought it - http://cgi.ebay.com/8GB-Design-FM-WM...arms=72%3A1205 )
Is there any other place or way, how to get the right firmware that i could try?
Old 25th May 2009, 2:12 am
Default Re: Recovering firmware
K9GAG is 2GB.
Also, 910589 is supposed to be identical to 910002, so try this one:
http://www.s1fw.com/Actions-ATJ209X/...589F-V2-0.html
Old 25th May 2009, 9:42 am
Thx. I tried this one, Player Update Tool works with that, but player is in same condition - only the sign "Starting" and hourglass is now mirror turned. Win still doesnt detect any UMS and Device Manager still shows just "Actions USB 2.0 (HS) WinUSB Device".
Old 26th May 2009, 2:02 am
Try the Product Tool. It has an Erase Flash function which may be what you need to clear/remap any bad blocks --- when the player stays at the hourglass screen, it's having problems verifying/loading the actual firmware, but since it can display the hourglass, at least we know your display and boot record got loaded correctly.
Old 26th May 2009, 3:11 pm
Its weird - Product Tool doesnt run on my computer (ntb Vista), where i can get player in Actions USB mode, on desktop with XP Product Tool run, but there i cannot detect player /it is there as Unknow device and i cant update driver to ADFU mode /
Old 27th May 2009, 1:13 am
Find another computer or figure out why the driver isn't installing properly. But that is the way to try.
Old 27th May 2009, 2:51 am
Finaly i get the Product Tool works on my ntb (HINT for anybody who will need this - enable Compatibility for the "batchproduct.exe", WXP SP2 mode works great) BUT ProductTool doesnt detect device :/
It seems that my "Actions USB 2.0 (HS) WinUSB Device" mode is not enough, so i tried to install proper ADFU driver and it works. BUT - what i should do now?
First step (flashing FW by Player upgrade tool) now doesnt works - so do i have to try anything else?
Product Tool detects player, but button "Erase flash" is disabled.
I really dont want to kill it completely
Old 28th May 2009, 12:14 am
I don't remember well but I think you have to select the player to be erased before that function enables.
Posting screenshots would be a good idea.
recovering firmware information compostcorner Dead Players 0 17th Sep 2009 10:27 am
I got Error while recovering my dead mp4 dragongel General Discussion 0 9th Sep 2009 5:47 am
Seriously Need Help with recovering my DEAD MP4 player atz Dead Players 0 5th Jan 2007 8:20 pm
help in recovering ACT_3.5.35 firmware allanc10s Support and How To 4 26th Nov 2006 4:37 am
After recovering my fake ipod its now only 1GB and not 2GB shay86 Support and How To 1 18th Nov 2006 3:31 pm
